Tire rotation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jp00714, Jan 22, 2017.
  1. Jan 22, 2017 at 5:40 PM
    Jp00714
    Jp00714 [OP] Active Member
    Jp
    06 pre-runner
    Hey guys. I'm running 35s on my Taco. How often should I be rotating them? Thanks
  2. Jan 22, 2017 at 6:08 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    In general rotation at 5 to 6k miles is sensible. Many do it when they change the oil which is a similar interval.
    Norton likes this.
  3. Jan 22, 2017 at 7:41 PM
    Pigpen
    Dan
    Northwest Montana
    The above info is correct. If you have any alignment issues, rotate them more often until the issues are resolved.
