Tire rub on cab mount
Discussion in 'Suspension' started by weiser5150, Apr 21, 2010.
  1. Apr 21, 2010 at 9:37 AM
    weiser5150
    weiser5150 [OP] Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    Installed billies at 2.5 and LR UCAs.Also 18x9 ATX Thugs 4.5 BS with 275/70R18 Toyo Mt's.I have done the normal trimming,but my tires are rubbing the cab mount.Can i fix this myself or should I take it to a fab shop?
  2. Apr 21, 2010 at 9:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you can weld, yes.
  3. Apr 21, 2010 at 9:50 AM
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    i cant weld though.
  4. Apr 21, 2010 at 9:52 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    How much would cost for a job like that?
  5. Apr 21, 2010 at 9:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    It shouldn't be too much. It just involves cutting the mount and welding a cap over the hole, and some paint.
  6. Apr 21, 2010 at 9:58 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    with all the dirt that fell out of the body mount after I cut it, We just decided to say screw getting it welded. I know plenty of people who have run it open like this for a long time with no problems.
  7. Apr 21, 2010 at 9:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    Good point. It looks like it would make cleaning it easier too.
  8. Apr 21, 2010 at 10:00 AM
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    did you cut that with a torch? sawzall? grinder?
  9. Apr 21, 2010 at 10:00 AM
    Dark Knight
    Jeff
    NC/SC
    yep cleaning is a snap with the pressure washer.
  10. Apr 21, 2010 at 10:01 AM
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    also,did you have to do both sides?
  11. Apr 21, 2010 at 10:01 AM
    Dark Knight
    Jeff
    NC/SC
    Angle grinder with a cutoff wheel. Touched it up afterwords with the regular grinding wheel.
    Both sides.
  12. Apr 21, 2010 at 10:02 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    You could cut it yourself with a sawzall (plenty of pics on this site) and make cardboard templates of the new plates. It would save you some money because all the welder would have to do is trace the templates, cut them out, and weld them on. When he's done, you can finish the job with $8 worth of primer and paint.
  13. Apr 21, 2010 at 10:23 AM
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    thanks all for the info.
