Tire rub w/ Dura's - 265/75/R16 ??
Discussion in '1st Gen. Tacomas (1995-2004)' started by HeadPin21, Jan 27, 2011.
  1. Jan 27, 2011 at 5:45 PM
    HeadPin21
    HeadPin21 [OP] Member
    Alexandria, VA
    04 SR5 TRD Dbl Cab
    Rough Country 2.5" suspension lift; 1,000W power inverter; billet grille
    I have a 2004 with a 2.5" Rough Country suspension lift and plan on getting a set of 265/75/R16 DuraTrac's. Will there be any tire rub with this combo; front or back?
  2. Jan 27, 2011 at 5:46 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Maybe on your mud flaps up front but thats it
  3. Jan 27, 2011 at 5:55 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I have 265 75 16 AT tires with a stock suspension and the only time they rub is when they are locked out and its flexing. Nothing bad at all so you should be good with a 2.5" lift!
  4. Jan 27, 2011 at 7:35 PM
    Itsallgood
    Itsallgood Awww, we got this!
    Midland, Texas
    2003 Xtra Cab Red V6 4X4
    Deck Plate, K&N, Grey Wire Mod, Magnaflow Dumped,Goodyear Duratracs-265/75/16,OME 3 in lift,LR Upper control arms, Wabfab sliders, homemade bed bar, 4XInnovations class 3 rear bumper, Trail-Gear low pro front bumper with Warn M8000 winch & LED turn signals
    I have the same tire on stock wheels with an OME 3 inch kit. Fits fine I went ahead and did the pinch weld mod also.
  5. Jan 27, 2011 at 9:15 PM
    HeadPin21
    Alexandria, VA
    04 SR5 TRD Dbl Cab
    So I shouldn't have to worry about adding spacers?
  6. Jan 28, 2011 at 4:37 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    you can add wheel spacers if you want to for the wider stance but your not going to have to.they are only 1'' taller over stock,youll be fine.
    from the online tire size calculator
  7. Jan 28, 2011 at 4:44 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah you will be fine if anything they will look to small with a 2 1/2" lift.
  8. Jan 28, 2011 at 4:47 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    This
  9. Jan 28, 2011 at 4:56 PM
    BSPDX
    BSPDX Well-Known Member
    I'm running 265/75/16's DT's with stock rims and no lift and have never rubbed
  10. Feb 14, 2011 at 3:25 PM
    BadMFer
    BadMFer Member
    Josh
    Chattanooga, TN
    03 TRD Tacoma
    K&N air filter, 31 BFG all terrains
    im running 265/75/R16 BFG all terrains w/ no lift and stock rims and they want to rub like a bastard. ive cut some of the plastic away and beat the piss out of the little metal lip w/ a hammer, sprayed down with black rustoleum, and fixed. only rubs now when bottoming out.
