Tire Rub with fender trimming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PRINCE SHEMBO, Jul 29, 2014.
  1. Jul 29, 2014 at 4:20 PM
    PRINCE SHEMBO
    PRINCE SHEMBO [OP] Member
    North Carolina
    10 TRD Offroad D-Cab 6 Speed
    5100's all the way around, Smoked Tail Lights
    Hello,
    I have a 2010 DC short bed with Billy 5100's all the way around with the fronts at the 2.5 setting and wheelers AAL in the back. I have wheels with a 4.5 inch backspace and I am running 285/75/16 Yokohama Geolander AT tires but with the 4.5 inch backspace and some inner fender trimming the tires still rub at full lock. My question is if I were to add a small wheel spacer would it help with the rubbing issue? If anyone has any pics that are running 4.5 inch backspaced wheels with spacers as well it would really help.
  2. Jul 29, 2014 at 4:22 PM
    ironman_jon
    ironman_jon Well-Known Member
    Jonathan
    Prerunner Sport
    URD TCAI Wicked Flow 18" 2 10in alpine type r 1500 watt amp MB 72 matte black Custom Bumper Debadged Glassworks fenders McNeil bedsides Helix TB Spacer Intake Manifold Spacer Custom Roof Rack 5x 55w HID SK2 projectors 55w DDM 5k Bulbs Camburg Long Travel Fox Coilovers
    Cab Mount Chop is more then likely needed.
  3. Jul 29, 2014 at 4:24 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    It's not the wheels. It's your caster and they need to be moved forward. Alignment numbers will tell the story. Ideal setting would be zero camber, zero toe, +2.5 caster at the least. Usually not attainable without going aftermarket upper control arms.
  4. Jul 29, 2014 at 4:57 PM
    PRINCE SHEMBO
    North Carolina
    I have the Camburg UCA's with the 1.25 uniball so this can't be it I wouldn't think.
  5. Jul 29, 2014 at 9:11 PM
    PRINCE SHEMBO
    North Carolina
    I am pretty positive it is rubbing in the back part of the inner fender closest to the front doors. I know lifting it a little higher by getting some OME 885 coils with the top plate spacers and setting the billy's back down to the 0 lift setting is an option but I was just wondering if the wheel spacer would be a quicker cheaper fix.
  6. Jul 30, 2014 at 2:03 PM
    PRINCE SHEMBO
    North Carolina
