Tire rub
Discussion in 'Wheels & Tires' started by utmck, Apr 29, 2011.
  1. Apr 29, 2011 at 4:07 PM
    utmck
    utmck [OP] Active Member
    I have a stock (no TSB) 2006 DCSB 4x4 Sport and changed out the tire/wheel combo to 16x8 & 265/75/16 BFG A/T.
    My issue is tire rub. When I measure from the ground to the bottom of my fender, the front measures 35" & 37" in the back. If I wanted to level the front of my truck would that help the tire rub situation?
    And if so, what would be my best way to accomplish that?
  2. Apr 29, 2011 at 4:16 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    A leveling kit would most likely fix that. You can get a small spacer that will do the job. I think revtek and daystar make products for that. Or you could get a set of bilstein shocks and that will allow you to adjust the height
  3. Apr 29, 2011 at 5:29 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You shouldn't be rubbing with just 265/75/16's. What is the backspacing of the wheels?
  4. Apr 30, 2011 at 10:56 AM
    utmck
    Not sure what the back spacing is, but the tires do stick out about 1/2" past the fender.
    What effect would a "spacer" have on the ride?
    Also, what does it typically cost to have shocks put on ones truck?
    Thanks.
  5. Apr 30, 2011 at 12:21 PM
    KPT
    09 Prerunner
    If they stick out that far past the fender with only 265's on there, you probably have too little backspacing (tires stick out too far out).
    A lift might fix it (avoid leveling kits and spacers lifts IMO)...but wheel spacers will likely make it worse.
    You should figure out the backspacing. All you need is the rim width and the offset, both of those shoudl be stamped on the rim.
