Tire rub
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000toyota, Jun 24, 2012.
  1. Jun 24, 2012 at 2:27 PM
    2000toyota
    2000toyota [OP] Member
    2000 Tacoma 4x4
    I have a 2000 tacoma 4x4 trd that I just bought a couple of weeks ago. The truck came with over size tires and if turned real sharp they rub. The truck also feels every bump in the road. The truck still has the stock suspension and I was thinking of upgrading the shocks to the 5100's. Do you think that will help with the tire rub and rough ride? Thanks.......
  2. Jun 24, 2012 at 4:29 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    If your stock springs are shot I would replace those too. Shocks alone will help but I would do them all at the same time since you need a spring compressor just for the shocks. Look into some replacement coils like OME 881's or 882's if you run aftermarket HD bumpers and some 5100's set at 0 or OME Nitros. As for the rear there are many options from stock replacement to lifted and custom built. Check out Wheelers Offroad.
  3. Jun 24, 2012 at 4:30 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    What size are these "over size tires", specifically?
  4. Jun 24, 2012 at 4:53 PM
    2000toyota
    2000 Tacoma 4x4
    265/75R16
  5. Jun 24, 2012 at 5:27 PM
    TexasTacoma37
    You shouldn't need a lift to run those. I'm thinking your stock springs are shot and sagging.
  6. Jun 24, 2012 at 5:37 PM
    sirsaechao
    Tim
    CA
    It's weird my first set of wheels at 1500 miles on the odometer from Ultra with 4.25" backspacing and 265/75R16 rubbed the plastic just above the mud flaps but my current Pro Comp wheels with 4.5" bs wheels and 265/75R16 never rubbed and I had the second set after 45000 miles on the odometer.
  7. Jun 24, 2012 at 5:47 PM
    2000toyota
    2000 Tacoma 4x4
    So do you think bilstein 5100's with OME 881 springs? I don't want to put a lift on the truck but would like a better ride and hoping to stop the tire rub.
  8. Jun 24, 2012 at 5:50 PM
    sirsaechao
    Tim
    CA
    According to Wheeler's no lift would be the 880's with their 4-pack leaf by Alcans. I am in the same boat. I enjoy the stock look but spending the $ on 880 and 4-pack vs 881 and 5-pack is a mere $10 more. The spring cost the same and the leaf is $10 difference.
  9. Jun 24, 2012 at 6:54 PM
    amocat 777
    amocat 777 Well-Known Member
    Tacoma Doublecab
    I had a minimum rub in front w my tires, 265 75/16 . It's Prerunner, but replaced w the Toytec Ultimate lift. Bilstein 5100 all around, and add a leaf. The front are adjusted to 2.5 ". No more rub, and possibility for 33" in future. I have had every kind of shock in past on trucks and jeeps. The 5100 is the best so far. I know you like the stock ride height, but this is a minimal difference.:notsure:
  10. Jun 25, 2012 at 7:09 AM
    wicked4x4
    wicked4x4 New Member
    Wick
    San Diego CA
    03 Tacoma 3.4L 4X4
    3" AllPro front/rear, AllPro bumper & skids, intake, custom routed exhaust, gray-wire, 33's, tubbed firewall, cut fenders, rock-rash
    isn't this stock tire size, not oversize for a 4x4? my truck (03 4x4 trd) came with these tires on it, no rubbing till we went to bigger (oversized) tires.
    kinda sounds like your suspension is real saggy, unless you've got some weird backspacing going on with the wheels...
    question for you - it only rubs when you turn sharp, is it rubbing the frame, or the body/tub/plastic?
  11. Jun 25, 2012 at 11:18 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I had the same problem with my truck when I put new 265/75/16s on. The front coil springs were completely shot and the coils were touching. The rest of my suspension was done too but I only had rubbing in the front. Same tires on my brothers stock 97 4runner has no rubbing. I think the TRD progressive rate coils don't last as long as the linear springs.
    265/70/16 is the stock size
  12. Jun 25, 2012 at 11:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    x2 Toyota calls them "oversized". The "oversized" tire on the 98-00 was 31 x 10.5 - 15
