Tire Rub
Discussion in 'Wheels & Tires' started by FoxTaco, Dec 8, 2009.
  1. Dec 8, 2009 at 6:25 PM
    FoxTaco
    FoxTaco [OP] Hoyt and Tacoma for life!!
    Joshua
    Fresno/Kingsburg, Ca
    09 4x4 Fox coilovers w/black rims
    AFE cold air intake, TRD Cat-Bak, Fox 2.5" resevoir coilovers & 2.0 rear Fox Shox from All-Pro Offroad.com, Daystar 2 1/2" leveling kit, , RBP black mesh grille, Panasonic double din touchscreen (flush(no flip out))
    I have very slight tire rub when i flex and have my wheel turned just the right way. What is the best solution for this? I have read that grinding the frame works, but will that make a weak point in my frame? What about wheel spacers? My buddy has an '05 Taco and swears by his 1/4 inch spacers. What have you done/use/liked the best? Thanks!!
  2. Dec 8, 2009 at 6:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Cut and Box the body mount. It wont weaken the frame.
  3. Dec 8, 2009 at 6:30 PM
    FoxTaco
    Joshua
    Awesome thanks! Thats what my other friend did.
  4. Dec 9, 2009 at 8:50 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Are you rubbing on your Cab Mounts or just inner plastics and fenders?
