Tire Rubbing Info
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01TacoTRD, May 28, 2008.
  1. May 28, 2008 at 7:16 PM
    01TacoTRD
    01TacoTRD [OP] Carolina Alliance: Quack Addict
    Chapel Hill, NC
    2001 Tacoma TRD 5 spd. 3.4 ltr white
    Does anyone know what the biggest tire is that I can get away with on a stock 1st gen taco with no lift? I'm thinkin about gettin 265/75r16 Nitto TG's and lift it when i get enough money. But while I dont have the lift, I was tryin to figure out how much rubbing would come from anything else and whats the biggest (or best (cheap tire too :)) tire I can get away with in the meantime while i wait for denero for the lift.
  2. May 28, 2008 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should only have minimal rubbing with that size. I had that size on my gen 1 and it only rubbed the frame at full turn. :)
  3. May 28, 2008 at 7:52 PM
    01TacoTRD
    Chapel Hill, NC
    thanks Chris! by the way im chris to. but while we are on the subject, have u heard anything about Nitto TG's and how they rate as far as quality on/off road?
  4. May 28, 2008 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are the only tire I run. I ran BFG's before, but I was asked to try out a set of the Nittos and see what I thought. Well, 8 years later, its all I run on my trucks. They have better grip in sand, mud, rock, granite, and under water than the BFG A/T KO's did. :)
  5. May 28, 2008 at 8:04 PM
    01TacoTRD
    Chapel Hill, NC
    thanks for the info man
  6. May 28, 2008 at 8:07 PM
    01TacoTRD
    Chapel Hill, NC
    I'm just a little worried that the 265 will look a little small for the yota! haha I love the off-road look that aggressive tires look. what do you think?
  7. May 28, 2008 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A 265/75/16 is considered a 32" tall tire. 10.5" wide at the section. Your tread width is going to be about 9.5", so Its a beefy tire. I run the same size on my Dodge. Had the same size on my 2000. I think it fills up the wells nicely. Regardless, its the largest size you can run without a lift, unless you have a Sawzall. :D
  8. May 28, 2008 at 8:13 PM
    01TacoTRD
    Chapel Hill, NC
    thanks! thats really ALL I needed to know. I couldnt make up my mind about them but im about 99.9% sure I'm gettin em now.
