Tire rubbing resolution
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cooper06quadcabLindhardt, Oct 25, 2016.
  1. Oct 25, 2016 at 8:24 PM
    Cooper06quadcabLindhardt [OP] New Member
    Cooper
    2006 Trd off road quad cab
    Ballistic wheels ko2s
    I have a 2006 quad cab Trd off road that has 265/70/70 ko2s. They rub on the inner fender walls. Any recommendations to remedy the problem? I Am skeptical of leveling kits because I don't want to sacrifice ride quality. I am thinking about cutting the inner fender wells
  2. Oct 25, 2016 at 8:25 PM
    Pigpen
    Dan
    Northwest Montana
    Even with a lift/ level you'll rub when the suspension flexes. Cutting is your best option.
  3. Oct 25, 2016 at 8:27 PM
    Pigpen
    Dan
    Northwest Montana
    Of course you could put on LR UCAs and adjust the caster so they don't rub too, and lift if you like... There are many options, but only one costs nearly nothing :sawzall:
  4. Oct 25, 2016 at 8:29 PM
    Cooper
    Yeah, that's true. Thanks!
  5. Oct 25, 2016 at 8:30 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    X2 ^
    Time to get out the dremel
