Tire Rubbing
Discussion in 'Wheels & Tires' started by Twiget, Nov 17, 2009.
  1. Nov 17, 2009 at 7:27 AM
    Twiget
    Twiget [OP] Proud to be Awesome
    America's Vancouver
    654, 6 Cylinders, 5 Speeds, 4 wheel drive
    Alpine Headunit, Soft Tonneau Cover, CAI
    I bought an '06 Tacom about a month ago. When I bought it, it had a set of aftermarket wheels and tires on it. They are 265/75/R16's, which I guess is wider than stock? Iniitally only the left front tire would rub.
    Long story short, the inner fender liner on the left front tire was damaged, and we figured that that was causing the rubbing. The dealer replaced the liner, and did a 4-wheel alignment. Now the rubbing is even worse! Oh, and I should mention that the right side rubs now too.
    How do I fix this? I know a lift, or spacers would probably do it. So would switching back to the stock tire sizes. Spacers I might do, depending on the cost. I want to keep the wheels and tires though, so going back to stock is not much of an option. Are there any adjustments that can be made?
  2. Nov 17, 2009 at 7:30 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Cutting the fender liner is what most do. If you don't want to do that go to a smaller tire
  3. Nov 17, 2009 at 7:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The tire size you are running is only 1" taller than stock, and the same width. Im betting its the wheel back space causing the rubb. Maybe a small lift on the front, dropping down to a 265/70/16, or a swap to different wheels that match the OEM's in back spacing..
  4. Nov 17, 2009 at 8:21 AM
    Twiget
    America's Vancouver
    What is the stock back spacing?
  5. Nov 17, 2009 at 8:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im pretty sure its 5.5"
  6. Nov 17, 2009 at 9:37 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    yeah its 5.5".
    I have a slight rub with my 265/75's but it only does it when I cut it all the way to the right and it is so slight I am not going to bother cutting anything. I have the DC1 wheels and their bs is 4.5 I think, so that is my problem, but it dosent bother me.
    If it is bad on yours, trim a little or going to a diff tire/wheel, or take my route and do nothing and live with it.
  7. Nov 20, 2009 at 7:34 AM
    Twiget
    America's Vancouver
    Now I know why the fender liner was cut up. The rubbing is pretty bad on the left side, and occasionally it will rub on the right. Unfortunately, not doing anything is not an option. It drives me crazy when my vheicles make noise when they are not supposed to. It looks like a slight lift might be in order.
    Does anyone have any recomendations on a 1"-2" lift kit?
  8. Nov 20, 2009 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Bilstien 5100's should suit you fine.
  9. Nov 20, 2009 at 8:30 AM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    But with factory wheels, the 265/75/R16 will not rub? At lest that is what I thought I had learned here. Correct?
    Thanks
  10. Nov 20, 2009 at 8:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...That size with factory wheels shouldnt rub.
  11. Nov 20, 2009 at 9:11 AM
    Twiget
    America's Vancouver
    Are the 5100's a straight bolt in swap? If not, what is involved in installing them?
    If 265/75/r16's will fit with stock wheels, this leads me to believe that the back spacing on my wheels is not stock. Is there anyone that makes spacers for the wheels that would put the back spacing to where it needs to be?
  12. Nov 20, 2009 at 10:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You need a spring compressor to install the factory spring onto the 5100's, but then its a straight bolt in.
  13. Nov 22, 2009 at 10:29 AM
    Twiget
    America's Vancouver
    Does the ride quality change with the 5100's? I noticed they are listed as race parts. Do they provide more wheel travel too?
  14. Dec 1, 2009 at 5:46 PM
    Twiget
    America's Vancouver
    :help: Bump
    Any thoughts?
