Tire Rubbing.
Discussion in 'Suspension' started by Tacomzz09, Mar 2, 2010.
  1. Mar 2, 2010 at 4:35 PM
    Tacomzz09
    Tacomzz09 [OP] Well-Known Member
    Calgary
    09 DBL CAB TRD Sport Towing
    Whats the best configuration to prevent rubbing on a 3 inch lift? Toytec UIltimate lift kit is what i'm aiming for at the moment
  2. Mar 3, 2010 at 8:41 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    That should do it!
    What size tires you thinking of running? The 285's?
    Just remember, if you go that large, the tire needs to be installed on an aftermarket wheel with 4 to 4.5 inches of back spacing built into the wheel.
    Hope that helps,
  3. Mar 3, 2010 at 9:04 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    if you want to keep the stock wheel you can also get spider trax
    1.25 wheel spacers
  4. Mar 3, 2010 at 9:17 AM
    BAMFTACO
    Juan
    Kings bruh
    I've seen other threads about 285 with wheelspacers and it seems to be fine and you get good enough clearance
  5. Mar 3, 2010 at 9:38 AM
    Sean
    Sean Member
    Calgary, AB
    09 Tacoma TRD
    OME 3"/AAL/LR UCA's, 285/70/17 Duratracs, Avid off road light bar, PIAA 520,Stubbs Welding HD-SKO Sliders, Extang Solid fold tonneau, Dyno Lock Tailgate lock, All Weather floor mats
    Can Total chaos UCA's be used in lieu of wheel spacers when running a 285/70/17 tire on stock TRD wheels, or are they still required ?
    I have searched the forums for an answer to this and have got conflicting answers.
  6. Mar 3, 2010 at 9:50 AM
    BAMFTACO
    Juan
    Kings bruh
    I not to sure cuz I've heard that the control arms help with alignment if you get a three inch lift and there stronger but if your on a budget wheel spacers $ 120 and if you have money control arms run you about $600 to $1000 depend wat company you go with too I recomend total chaos or camburg there a little bit cheaper than chaos
  7. Mar 3, 2010 at 12:12 PM
    Sean
    Sean Member
    Calgary, AB
    09 Tacoma TRD
    The cost of the spacers does not really concern me, I'd just rather not run them.
    And I know aftermarket UCA's correct alignment issues but after looking though various threads, some hint that they may possibly also provide more clearance between the inner sidewall of the tire and the UCA versus the stock UCA's
  8. Mar 3, 2010 at 1:38 PM
    BAMFTACO
    Juan
    Kings bruh
    Like I said if you have the money get it
  9. Mar 5, 2010 at 10:33 PM
    Tacomzz09
    Calgary
    yeah gonna run 285/70/18, is it good enough for clearance? If not would it require trimming? I am also not going to be using the stock rims.
