tire sensor broken 2016 TRD Sport
Discussion in 'Wheels & Tires' started by Kblack1968, Aug 26, 2019.
  1. Aug 26, 2019 at 12:59 PM
    Kblack1968
    Kblack1968 [OP] Active Member
    Kevin
    Ocean Isle Beach, NC
    2016 Tacoma Super White TRD Sport 4X4
    Eibach coil overs front and Deaver AAL rear. 17” TRD Pro wheels.
    can I replace the broken sensor or does it need to be programmed at Toyota
  2. Aug 26, 2019 at 1:01 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Needs to be programmed into the computer unless you buy a programmable sensor which would then need to be programmed to match your existing sensor.
  3. Aug 26, 2019 at 1:02 PM
    Kblack1968
    Kevin
    Thanks. Approximately how much at Toyota dealer to do this?
  4. Aug 26, 2019 at 1:05 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Couldn't tell you, I replaced mine with rubber stems.
