Tire shine
Discussion in 'Detailing' started by 808Bradah, Oct 18, 2012.
  1. Oct 18, 2012 at 4:15 PM
    808Bradah
    808Bradah [OP] Well-Known Member
    Hawaii
    2012 Super White SR5 4cyl
    Does tire shine affect the tires in a negative way or do they actually help the tires from cracking And fading as the description says on the can? Also if the overspray gets on the rims will it do anything to the rims?
  2. Oct 18, 2012 at 4:18 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Make sure the product is silicone free. If any gets on the wheels, just wipe the overspray off when your done.
  3. Oct 18, 2012 at 7:33 PM
    808Bradah
    Hawaii
    Mines has silicone, what happens if it has silicone?
  4. Oct 18, 2012 at 9:05 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Ah, I wouldn't sweat it... Even with silicone, if it gets on your brakes, you'll wear it off quick. I wouldn't worry about it.
  5. Oct 18, 2012 at 9:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Strictly cosmetic.
    The flexing of the tire while rolling migrates carbon black to the surface which protects the rubber from deterioration from ozone and ultraviolet.
    Trailer tires show cracks because they sit for months... not because someone used the "wrong" protectant.
  6. Oct 18, 2012 at 9:08 PM
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    I hate tire shine on my tires. I'll make them wash it off it it gets put on. Plus it seems to turns your tires brown.
  7. Oct 18, 2012 at 9:24 PM
    808Bradah
    Hawaii
    thanks for the info guys
  8. Oct 18, 2012 at 9:27 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ Same here... never cared for that look on a truck.
  9. Oct 19, 2012 at 10:17 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    wish I could find a treatment that makes them black, not shiny, I hate the stuff because it slings, no matter how much the manufacturer says that it doesnt, it still does. Any amount of applying and wiping you do, it still slings.
    I have used stuff called "blue tire dressing" that nets decent results, but it wears very quickly and you're right back to as if you never did it in the first place
  10. Oct 19, 2012 at 12:02 PM
    fishntaco
    Josh
    Mobile Al
    I like adams super vrt or optimum tire shine. I like tire shine that gives a matte factory look, which these two products do. They will also not sling when applied to a clean tire.
  11. Oct 19, 2012 at 12:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I use tire shine stuff all the time after I wash the truck....no particular brand in mind. I've never had a problem with tires or rims getting messed up from any of it. I just spray it on..... My stock tacoma tires lasted about 45K miles without issues (other than low tread) and my rims still look great!
  12. Oct 19, 2012 at 12:19 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    off topic but when I had my car I would just cut open a used clean bottle and pour some tire shin in it then use a paint brush to put it on the tires. that way you get no over spray and it goes on nice and thick .
  13. Oct 19, 2012 at 1:43 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Foaming tire shine works best for this. The foam evaporates and the tires are dry and black.
  14. Oct 19, 2012 at 4:24 PM
    RATEDXTACO
    RATEDXTACO Member
    Las Vegas
    13 SW trd sport
    just use tire dressing thats water based...not oil based, the use a cloth like sponge to apply it. let sit for atleast 10mins, then wipe it off with a dry towel.
  15. Oct 19, 2012 at 4:28 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    I dilute the turtle wax spray goop with water and wipe off excess. Leaves more of a matte finish instead of the crappy "shine" look.
  16. Oct 19, 2012 at 5:01 PM
    brianv3ntura
    brianv3ntura Well-Known Member
    Jacksonville FL
    MGM'12 Taco TRD Sport 4x4 DCLB 4.0L 5spd Auto
    Stock for now.
    actually all tire shines have some form of silicone. What really turns the tires brown is the chemical reaction between the tire and solvents used in the tire shine product.
    this is where you do your research and see which tire shine uses less solvents. the solvents opens up the pores of the tires and help make the shine stay on longer.
  17. Oct 19, 2012 at 5:18 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Voo doo ride, but has silicone. Nice black look.
  18. Oct 19, 2012 at 7:56 PM
    magnetic11
    "some nuke plant"
    11 trd sport
    If u want your tires black and looking new, i use bleach white
  19. Oct 19, 2012 at 8:52 PM
    Airun
    Aaron
    Show Me State
    Eagle One spray foam cleaner gives a nice black matte look as well
  20. Oct 23, 2012 at 6:42 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Meguire's High Endurance if you like shine and longevity. It's a gel so no overspray.
