Tire size after new front bumper
Discussion in 'Wheels & Tires' started by Missouriprerunner, Nov 18, 2015.
  1. Nov 18, 2015 at 12:55 PM
    Missouriprerunner
    Missouriprerunner [OP] Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    So if I swap out the front bumper for an All Pro or something similar would that leave more room for bigger tires? I have a 3in Toytec lift installed already (half inch puck with heavier coil, 3in total lift)
    I'm wanting to get new tires because I'm still rocking those 265/70 r16's lol but if the bumper adds for a slightly bigger tire than a 33 or something I'll wait till after I get the new bumper.
    I have a 2009 TRD off road taco prerunner, I go on trails but nothing crazy, biggest obsticals are the ocasional small fallen trees and small rocks.
  2. Nov 19, 2015 at 9:53 AM
    LikeABoss4x4
    LikeABoss4x4 Well-Known Member Vendor
    Sarah
    So Cal
    All-Pro's bumper will give added clearance up front... I ran it with 35s, but you will likely rub on the rear of the wheel well, so trimming is necessary for 33"+.
  3. Nov 19, 2015 at 10:00 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Sarah is correct. You will definitely have to chop the cab mount and remove the mudflaps. Some minor trimming to the fender liner plastic might be necessary too. Not much though. I trimmed a little more than normal people would for my 285's because I didn't want to rip up my tire on the pinch weld stuffing my 33's so I trimmed back and flattened it.
  4. Nov 19, 2015 at 10:56 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    I'm considering taking that half inch puck out and putting in a bigger one new UCA'S and then add the difference in the back so I can get bigger tires on still. Are blocks in the back bad and the only option for lifting up the rear?
  5. Nov 19, 2015 at 10:59 AM
    geekhouse23
    Blocks and spacers are always bad :gossip:
  6. Nov 19, 2015 at 11:34 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    I have one lead added on already, what else can I do
  7. Nov 19, 2015 at 11:35 AM
    geekhouse23
    Full leaf pack >>>> Progressive AAL > Single AAL
  8. Nov 19, 2015 at 12:32 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Thanks,
    I've decided to go with a 33x12.5 Atturo Trail Blade M/T tire on a 17x9 rim
