Tire size and backspacing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country101, Nov 5, 2012.
  1. Nov 5, 2012 at 4:34 PM
    Country101
    Country101 [OP] Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    I have a OME lift on my truck and stock 16" wheels. What is the biggest tire I can put on there without having to trim fenders and would I need a set of wheel spacers? I have done some searching, so dont flame me too hard, but I have seen lots of referances to 17" wheels and not so much for 16". I have 285/70/16 on right now.
    On a side note, could a "largest tire with X" lift" sticky be made? I know a lot of you guys have this kind of stuff memorized, but it might save a lot of posts like this. Just a thought.
  2. Nov 5, 2012 at 7:49 PM
    BradyT88
    BradyT88 Well-Known Member
    Well typically once you go to 33's and up you will start rubbing on the cab mount and no reasonable amount of lift will fix that, although a small backspacing and/or wheel spacers will help that some. I have about 3" of lift with 255/85R16's (33"x10") on 4.5" backspacing and I had to do some minor trimming to the fender flares and some of the plastic wheel well liner that is behind the front bumper. I rub on the cab mount and pinch weld occasionally but nothing major. The skinny tires help with that a lot though. If you wanted to stay wider, it will just make the rubbing that much worse, especially when offroading.
  3. Nov 6, 2012 at 5:40 AM
    Country101
    NW Arkansas
    I'll do some looking and see what other sizes are close to a 33" tire. I want to keep the wider tire though. As long as I dont have to rtim any metal, I'll be happy.
  4. Nov 6, 2012 at 6:07 AM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    Do your 285's rub right now? I am wanting to put 285's on mine but have read a lot about rubbing issues. They say trimming is a necessity.
  5. Nov 6, 2012 at 6:33 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    I have 16x8 rims with 4.5 BS - I am running 315/75 16 which is about 35" and a hair over 12" wide
    Had 33's before this so just had to do a little more pounding in the front since I already chopped the cab. I ended up running fiberglass fenders in the front. Didn't trim anything on the rear, just moved the axle back 1"
    This is on a 3" lift
  6. Nov 6, 2012 at 7:38 AM
    Country101
    NW Arkansas
    My 285's dont rub. I havent done a whole lot of off roading, but I should have done enough to have found out by now. It mainly stays on the road and some forest service trails.
  7. Nov 6, 2012 at 8:51 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Too many variable for a one size fits all thread.
    I'm running the same size tires (BFG KM2s) & same BS (16x7 1st Gen TRDs) as Brady and have had to do no trimming, and have no rubbing with my 3" OME lift and I still have front mud flaps on.
  8. Nov 6, 2012 at 10:21 AM
    BradyT88
    Oh I should mention I have a 16x8" rim, but yeah my mud flaps were gone instantly. It rubbed like crazy on them. Even the way your alignment is set can affect whether your tires rub or not.
