tire size and clearance
Discussion in 'Wheels & Tires' started by yodaoma, Oct 12, 2009.
  1. Oct 12, 2009 at 9:34 PM
    yodaoma
    yodaoma [OP] New Member
    2006 toyota tacoma SR5 4x4
    3" rough country suspension life, 4 pc billet grill. tires and wheels
    looking at purchasing some rims and tires for my truck. i've heard from a local mechanic that anything larger then a 285 tire probably wont work. i've lifted my truck 3" and am looking at purchasing a 17x9 rim. with a 285 70 R17 tire. does anybody have this combo, if so, any rubbing or interference?
  2. Oct 12, 2009 at 9:56 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Its going to depend on the offset/Back spacing of the wheels. Link to the wheels?
  3. Oct 13, 2009 at 9:16 AM
    yodaoma
    the weels have a -12mm off set and the bs is 4-1/2
  4. Oct 13, 2009 at 11:42 AM
    RelentlessFab
    Eric
    Sparks, NV
    ok, that isnt the ideal specs for clearing the 285s, but its ok. Many aftermarket wheels run those specs. You will probably have to remove the front mudflaps and trim a little bit of the inner fender liner in the front of the front wheel wells to keep from rubbing when turning. If you offroad a bunch or if your tires are some of the larger 285s, you may also find they rub the cab mount at times, in which case that may need the chop/replate mod done on it if its severe enough.
