Tire size and speedometer error
Discussion in '2nd Gen. Tacomas (2005-2015)' started by socal147, Apr 7, 2012.
  1. Apr 7, 2012 at 3:32 PM
    socal147
    socal147 [OP] Active Member
    patrick
    Apple Valley Kalifornia
    12 PreRunner SR5
    Just Bought It = NONE
    Ok, So on my Jeep JK I could program the computer to adjust the speedo for different tire sizes. I know that that Taco cant be reprogrammed to do this? So what does everybody do to adjust the speedo to read correctly....or do you do nothing and just accept the speed error.
    Thanks
    Patrick
  2. Apr 7, 2012 at 3:42 PM
    Dustyroades
    Dustyroades Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    In most cases, moving up one tire size actually corrects the speedometer to read accurately, and makes the odometer read a little slow.
  3. Apr 7, 2012 at 5:21 PM
    socal147
    patrick
    12 PreRunner SR5
    Very Good,
    Thanks. :)
  4. Apr 7, 2012 at 9:55 PM
    badger
    badger Well-Known Member
    07 SR5
    You can calibrate it and correct it perfectly using a Dakota Digital signal generator.
  5. Apr 8, 2012 at 12:22 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    That's correct!
    STOCK: 265/70-16 when my speedo showed 68 mph, my GPS showed 65.
    NOW: 265/75-16 (1" taller tire), both speedo and GPS are the same!
  6. Apr 8, 2012 at 10:56 AM
    jjbsocal
    jjbsocal Well-Known Member
    Jeff
    So☆Cal
    2010 DCLB PreRunner TRD Sport
    Camburg MT; 4.0 Spindles and UCA's, Fox Extended Travel with Resi's all 4 Corners, All Pro Expo Leaf Pack, Method Standard's, BFG AT's, DTLT's, 1st Gen TRD CAI, Magnaflow Pro Offroad Exhaust..
    I have the Hypertech In-Line calibrator in my 2010 and it works fine.. It can be programmed for tires and gears..
  7. Apr 8, 2012 at 11:03 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    My speedo was off 3-4 at highway speeds. Its correct now with 265/75/16 on.
  8. Apr 8, 2012 at 11:10 AM
    tommyg29
    tommyg29 Well-Known Member
    South Miami, FL
    12 DCLB PreRunner Sport
    assuming these trucks are all calibrated the same, anyone know the best tire size for accurate reading with the 4x2 17" trd sport setup?
    I have those radar speed signs in my area but havent used one yet to tell my speed. Another way I do it is timing and watching my speed over a known mile or half mile, but thats not as accurate.
  9. Apr 8, 2012 at 11:20 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I just use my GPS and cruise control. According to my GPS at 70 mph when I run my stock 245/75/16 Dungflops I'm going 2 mph slower than my speedo says & when I put on the 255/85/16 BFG KM2s I'm going 4 mph faster than the speedo says.
    Those came with 265/65/17s so move up to 265/70/17s and your speedo should be correct.
