Tire size and warranty
Discussion in 'Wheels & Tires' started by Trackmaster, Jan 15, 2009.
  1. Jan 15, 2009 at 3:21 PM
    Trackmaster
    Trackmaster [OP] Active Member
    TRD 4X4
    I switched from the factory 265\70\r16 to 265/75/r16 now the dealer is telling me this will void my power train warranty. Just wondering if anyone else has had this problem.
    Thanks
    Trackmaster
  2. Jan 15, 2009 at 7:35 PM
    Aldo ct
    Aldo ct Well-Known Member
    central California
    97 Tacoma 2rz
    LC header, prerunner/4x4 front end, hellwig rear sway bar/beefed brackets, instrument cluster w/tachometer, 60/40 bench seat, solid sideview mirrors, slider rear window, rearview mirror w/map lights, 27x8.50r14 tires
    Hmmm, my sister has an 02 4x4 with the trd offroad package and she bought it with 265/75/16 tires. They are falken tires so they are not the original tires, but don't the 01-04 4x4 trd tacomas come with 265/75/16 tires?
  3. Jan 15, 2009 at 7:50 PM
    Trackmaster
    TRD 4X4
    Not for sure was just wondering if anyone else has had their dealer say anything.
  4. Jan 15, 2009 at 8:17 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Per the Magnuson-Moss act, unless the dealer proves that your tires are the cause of a failure in your powertrain, your warranty can not be voided by law. If i were you, I would simply consider using a dealer that wont mess with you like this. That is if it is convenient for you. JMO
    There are also a few threads on the site that speak of the Magnuson-Moss act, and warrenty issues. Use the search feature and I'm sure you'll come up with some good information.
  5. Jan 16, 2009 at 3:20 PM
    Trackmaster
    TRD 4X4
    Thank you for your help I will be checking that out.
