tire size change=speedometer problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wawuzit, Jan 30, 2019.
  1. Jan 31, 2019 at 9:02 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    No, it's not.. It's off by a percentage not a fixed MPH number. The faster you go, the more "off" it will be.
    Going from 265/70/16's to 285/75/16's is approximately 7.2%.
    mynewtoy and paleh0rse like this.
  2. Jan 31, 2019 at 9:14 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    A plus is that you get a few more miles out your warranty if you don’t recalibrate...
    JNG, Yann and nartmot like this.
  3. Jan 31, 2019 at 10:57 AM
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    You’re not going fast enough To see a difference. Go 65+ and depending on the size, you’ll see a speed difference.
  4. Jan 31, 2019 at 11:07 AM
    lynyrd3
    Bill
    East Central Upstate NY
    69 mph on speedometer 72 on UltraGauge , 55 on speedometer 58 on UltraGauge ,72 on speedometer 75 on UltraGauge :notsure: Lifted just under 3” with 285/70 17s .
  5. Jan 31, 2019 at 11:07 AM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    This is just an assumption on my part, but Toyota sells the Tacoma with various wheel sizes, and I'm assuming they don't individually calibrate those trim levels. If that's the case, they're probably calibrated to find some middle ground that isn't too "off" for any of the stock sizes.
    Toyota couldn't even be bothered to customize/align the overlay with the backup camera for the Taco. So my guess is that you're probably already starting from an inaccurate reading even before you change the wheels. I could be full of crap, though.
    TacoTim16, JNG and lynyrd3 like this.
  6. Jan 31, 2019 at 11:09 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    This is the correct answer.
  7. Jan 31, 2019 at 11:16 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    UltraGauge must be off? Or Speedo? If nothing else changes the math doesn't support 3 mph constant difference.
    at 20mph you should be off by ~1.5mph
    at 80mph you should be off by ~6mph
  8. Jan 31, 2019 at 11:17 AM
    paleh0rse
    Raleigh, NC
    I believe using the revs/mile numbers for varying tires provides a more accurate % for mileage, fuel efficiency, etc.
    For example, my stock TRD Off-road 265/70R16 Goodyears were 682 revs/mile.
    My new tires, Cooper ST Maxx 255/85R16's, are 632 revs/mile.
    682/632 = ~1.079
    Therefore, in order to calculate true MPG, etc, I multiple the displayed value by 1.079 -- which is a ~7.9% difference.
    (The revs/mile specs can usually be found on the tire manufacturer or retailer websites).
  9. Jan 31, 2019 at 11:19 AM
    greengs
    AB, Canada
    This site has it all, including mph speedo error at various speeds. Someone already posted it, but here it is again.
  10. Jan 31, 2019 at 11:22 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Yes your right. I don’t really care about miles shown though I’m keeping it forever but it does show less miles than it actually has
  11. Jan 31, 2019 at 11:23 AM
    TSmoove
    Trevor
    Atlanta, GA
    2017 Tacoma
    All Tacoma’s stock will come with 30 inch tires, so going with any thing greater than that will throw off the speedometer. The larger you go, the more apparent the change
  12. Jan 31, 2019 at 11:24 AM
    paleh0rse
    Raleigh, NC
    Calculators like that one provide a rough estimate, but they're not as accurate as using the actual revs/mile measurements for each specific tire.
    tiresize.com even provides the following caveat for their calculator:
    "Individual tire specs may vary from the calculations. However, you can choose from the populated list of tires to view the manufacturer specs for each tire."
  13. Jan 31, 2019 at 11:28 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    You have a 2nd gen, not the same thing.
  14. Jan 31, 2019 at 11:29 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    My speedo was dead on with the factory Goodyear's. It's still pretty damn accurate with the Hypertech (slowly getting inaccurate due to tire wear).
