Tire size feedback
Discussion in 'Wheels & Tires' started by vprgts, Jul 22, 2011.
  1. Jul 22, 2011 at 4:32 PM
    vprgts
    vprgts [OP] Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    I'm about to do a 6" Fabtech lift on my 2011 DC LB Tacoma. Should I roll with a 325/65/18 or 295/70/18? I've been told I should consider the smaller because of less cutting, rubbing, etc. Regardless, my rim offset is -12 and they should stick out a bit but will it look swiss if I go with the narrower tire. Just looking for some feedback, thanks!
  2. Jul 22, 2011 at 4:34 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    are you planning on doing a gear change?
  3. Jul 22, 2011 at 4:37 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Go big or go home...isn't that the moto?? :laugh:
    Swap your gears out with some 4.88's
  4. Jul 22, 2011 at 5:22 PM
    vprgts
    Walter
    Centreville, VA
    Most likey I will change up the gears but at first just the lift, wheels and tires. Where/what kind of gears should I look for?
