Tire size for spedometer calibration
Discussion in 'Toyota Trucks & SUVs' started by T-Rex266, Mar 24, 2011.
  1. Mar 24, 2011 at 6:59 AM
    T-Rex266
    T-Rex266 [OP] T-Rex Moderator
    Hello! Newb here with a 09 Tacoma TRD double cab, 5spd auto, rear lockers, a-trac. I'm looking at putting 32" Hancook tires on 17" Procomp wheels here shortly and want to know if I will need to have my speedometer calibrated?? What about gears?
  2. Mar 24, 2011 at 7:18 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    http://www.tacomaworld.com/forum/tirecalc.php
    You shouldn't have to regear unless it's for personal preference or for a specific use (towing, off roading, etc). Obviously you'll lose a little power with the larger tires but it won't be a dog. This link will tell you how far off your speedo will be with your new tires.
  3. Mar 24, 2011 at 7:26 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    I'm running 285/75/16 and my speedo is only 3mph off I used my gps
  4. Mar 24, 2011 at 9:12 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Weird...
    My speedo was off by 3 mph (too fast) with the stock 265/70-16 Rugged Trails. When I put on the 1" taller 265/75-16 Dynapros, it was spot on.
  5. Mar 24, 2011 at 11:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you verified your speed with a GPS?
    The speedo that you see on your dash isn't necessarily accurate. I know my computer (ECU) is accurate againest GPS, but the speedometer that I see on the dash is 2mph fast. I have a Scanguage that reads the ECU.
  6. Mar 24, 2011 at 3:12 PM
    T-Rex266
    Thanks guys! Are dealerships the only one who can calibrate a speedometer? What would it cost to get that done?
  7. Mar 24, 2011 at 4:22 PM
    David K
    Of course, how else would I know it was off?
