Tire size/gear ratio affect on speed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ibicycle2, Nov 17, 2020.
  1. Nov 17, 2020 at 2:53 AM
    ibicycle2
    ibicycle2 [OP] Member
    Iowa
    2018 Tacoma TRD OR
    475X70X17 - 4.88 gears
    I have a 2018 Tacoma with 275/70R17 tires (32.2" diameter) and 4.88 gears. The truck came stock with 265/70R16 tires (30.6" diameter) and 3.90 gears. Driving down the highway speedometer is showing 65MPH, but actual speed is more like 68. Not really a huge deal, but with the changes to tire size and gear ratio it seems to me like the speed reading difference should be the other way around (going slower than speedometer reading)?
  2. Nov 17, 2020 at 2:58 AM
    ibicycle2
    Iowa
    2018 Tacoma TRD OR
    OOOh...that makes sense. I AM from the "olden days" and sensing speed from transmission was what I had in my head. THANKS
    Boghog1 likes this.
  3. Nov 17, 2020 at 3:18 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  4. Nov 17, 2020 at 4:10 AM
    T00CH
    T00CH Well-Known Member
    Anthony
    Canonsburg, PA
    2020 Tacoma TRD OR
    I have 295/70/17's on mine and it's off by almost 5mph. I tend to have my Android Auto going so I always watch the GPS speed. Your speedometer shows your going slower as your tires are rotating slower than they were before with the bigger size. 659 revs/mile with your 265's compared to 627 with the 275's
    Taco_Coma likes this.
  5. Nov 17, 2020 at 6:18 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    When changing gears or tire dramatically you should have the dealer do a zero point calibration. Your vsc and abs think you have closer to stock tire diameter. I had to do it in my Land Cruiser but don't know if Tacomas have the same or similar system as the LC.
  6. Nov 17, 2020 at 3:47 PM
    ibicycle2
    Iowa
    2018 Tacoma TRD OR
    My dealer in Iowa told me it was against the law for them to modify the speed/miles calibration?
  7. Nov 17, 2020 at 3:50 PM
    stevesnj
    Dunno. Seems like you're calibrating it not modifying it.
    Boghog1 likes this.
