Tire size help?
Discussion in 'Wheels & Tires' started by colton1219, May 10, 2011.
  1. May 10, 2011 at 8:30 AM
    colton1219
    colton1219 [OP] Active Member
    Arizona
    SR5
    4.88 gears, ArB Bumper, ARB lockers front and rear
    I have 285 70 17 KM2 tires and rub to much even with my lift. I have 4.88 gears and a 6 speed to boot so my rpm get a little high.I have considered a 255 85 16 but they are pricey and they will still probably rub?I want to know if I went from a 32.5 tire (my 285 70 17 s') to a 235 85 16 or a 265 70 16 that is only 31.5 tall if it would help or hurt my MPG. I will be going to an A/T tire and also saving about 15 lbs each wheel. My RPms' will go up about 200-400 because of a smaller tire but what do you guys think ,will I help myself with fuel consumption?Thanks
  2. May 10, 2011 at 10:37 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What is the backspacing of your rims, and the specs of your lift?
    Did you trim any fender well plastic? Chop the cab mount?
  3. May 10, 2011 at 4:24 PM
    colton1219
    Arizona
    SR5
    Backspace is 4.5 and no trimming witch I really dont care about the rubbing, the issue is I want to better my mpg . My question is more about running the different tire sizes and gear ratio I have to get the best MPG?
  4. May 11, 2011 at 6:52 AM
    colton1219
    Arizona
    SR5
    46 views and no opinions ,there is another post about 255 tires right now and there are 3 pages . I know somebody can help with my mpg questions ?
  5. May 11, 2011 at 8:49 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Higher RPMs are going to use more gas, but your driving style is going to make more of a difference. I wouldn't be running 4.88's unless I had 295+'s mounted.
    The question I have for you is, why did you regear?
  6. May 11, 2011 at 1:18 PM
    colton1219
    Arizona
    SR5
    Bought the truck that way, and i got a great deal so my question is What tire size do you think I should run to help myself for MPg's with my set up not factory gears? Thanks
  7. May 11, 2011 at 1:43 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    If you drive off road I would run Load range C, AT tires. If you are always on the road choose high quality P rated truck tires. You are going to have better results running bigger tires, I would probably stick with a 285/70 17.
  8. May 11, 2011 at 2:54 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    with 4.88s, 35" or 37" tires...
    i have seen a couple tacos running 4.88 on 33s and they were burning up rubber pretty bad...
  9. May 11, 2011 at 8:02 PM
    colton1219
    Arizona
    SR5
    what do you mean burning up rubber? Are they wearing any faster than normal ?
  10. May 11, 2011 at 8:07 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    because of the over-gearing, when they accelerated from a stop, they were peeling out a lot...
  11. May 12, 2011 at 5:31 AM
    colton1219
    Arizona
    SR5
    Thought that would have been a throttle issue?
