tire size help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by northtacoma, Jan 24, 2012.
  1. Jan 24, 2012 at 10:26 PM
    northtacoma
    northtacoma [OP] New Member
    Rian
    i just purchased 265/75r16
    they look great hancock at ft10
    but they rub just a little man what a bummer the tire shop said they would exchange them is there anything i can do? or do i need to quit thinking that my truck is lifted and get the 265/70's put back on and be thankful the tire guy is being cool.
    any other advice about tires in relation to my 04 trd stock tacoma would be greatly appreciated.
    thanks
  2. Jan 24, 2012 at 11:53 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    where is it rubbing? 265/75/16 should clear at stock height.
  3. Jan 25, 2012 at 11:14 AM
    northtacoma
    Rian
    The rear part of the front fender when I turn about 80 degrees
  4. Jan 25, 2012 at 11:33 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    do you still have your mud flaps on? is this the area you're referring too? if it is, try taking them off. are your front springs sagging?
  5. Jan 25, 2012 at 2:50 PM
    northtacoma
    Rian
    no i just had the spings replaced, and there are no mud flaps on the front
  6. Jan 25, 2012 at 8:03 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    i guess those tires run a little taller and/or wider than other brands. your only solution is to downsize as you mentioned or get some billy 5100s upfront to add a mild lift which will give you the clearance.
  7. Jan 25, 2012 at 8:12 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    If its just the plastic wheel well .... Take a sharp blade to the lump of plastic that's rubbing and trim it. Nobody will even know/notice it!
  8. Jan 25, 2012 at 8:16 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    weird, that's the stock size. they shouldn't be rubbing.
  9. Jan 26, 2012 at 8:22 PM
    northtacoma
    Rian
    is my off roadng going to be affected by the smaller tire size i haven't run he new tires off road but am curious as to the pros and cons
    thanks
  10. Jan 27, 2012 at 4:43 PM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    dont worry my 265/75/16 good year wrangler td's rub to just cut the plastic in the back it will end up rubbing a hole in the plastic. mine did
