Tire size/lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaes843, Sep 26, 2012.
  1. Sep 26, 2012 at 4:50 PM
    tacomaes843
    tacomaes843 [OP] Well-Known Member
    03 Prerunner SR5
    3.5' lift in the front w/ Bilstein 5100 Shocks & Eibach Coils, 1.5' in the back with blocks & billies. Tinted windows. Tinted Tail-lights. Blacked out corner lights. Uws tool box. Whip Antenna. 2nd gen 16' wheels. Flowmaster 40 dual exhaust. 1.25' Wheel spacers all around.
    Hey guys I am currently running stock 31's on my Tacoma with bilstein 5100's set at 2.5. I love em they ride so well way much better than stock. I'm just wondering if I could fit 33's preferably the 12.50's. I know I'd probably have to do some trimming and maybe get some wheel spacers. Just lemme know what y'all think! Thanks guys
  2. Sep 26, 2012 at 5:05 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    A search would answer your question AND any other question you could come up with for this topic...But I believe you would want to get eibach coils up front for a full three inches (be sure to set the 5100s at 0 if you go that route) and an AAL/new leaf pack in the rear if you don't have any lift back there yet. I wish I had experience putting 33's on my truck to be more helpful, but I don't have the money to start experimenting just yet :eek:
  3. Sep 26, 2012 at 5:17 PM
    tacomaes843
    03 Prerunner SR5
    That's what I want to get I just don't have the money right now so I was wondering if I could just pull it off with what I have now. Haha I hear ya man we're in the same boat!
  4. Sep 27, 2012 at 9:29 AM
    Tacoma9396jrc
    Tacoma9396jrc Well-Known Member
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Cherry Bomb exhaust, 3" suspension lift
    I fit 33x12.50s on my 2.5 spacer lift. I had aftermarket wheels which caused the tires to stick out some. but they arent even close to scrubbing. The plastic on the front bumber needed to be trimmed just a little. but ive lifted it more since then. so no scrubbing. but you can definitly do it
  5. Sep 27, 2012 at 5:41 PM
    tacomaes843
    03 Prerunner SR5
    thanks man appreciate that it defiantly helped! bet your truck looks good
  6. Sep 27, 2012 at 7:32 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    I'll post a pic if you want any ideas for yours?
  7. Sep 28, 2012 at 12:45 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sure if you don't mind doing some cutting and hammering
  8. Sep 28, 2012 at 6:40 AM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    This is after the body lift.. Ill post one of the 33 with just the spacer lift
  9. Sep 28, 2012 at 6:43 AM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    This is with just the spacer. like i sadi it scrubed a little on that plastic piece on the front bumber. If youre still running stock wheels you may have to get wheel spacers tho
  10. Sep 28, 2012 at 7:42 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you can run 33s are that lift. You'll just have to do a bit more trimming and hammering them most. Nothing drastic tho.
    12.5s are wide, i know. Backspacing is key to run them. 3.75-3.5" is best. The bigger the backspacing, the closer to the UCA and more you'll rub on the frame when turning. The Lower the backspacing the more you'll rub on the fenders.
    33x12.5r15s at 4" backspacing. 3'' lift up front 4.5 out back.
    2012-01-14_14-23-56_730_c32b5082e4732ed0fea5f273060c377006eb23b6.jpg2012-01-14_14-24-18_235_31cef0b4bfb9ae3e83f2ba5e6b3034f8b3b6f8aa.jpg
    33x12.5r15 at 2.5'' backspacing. Honestly this is too low. Had to cut and hammer a lot outa the fenders. Looks sweet tho..
  11. Apr 15, 2013 at 11:57 AM
    blake.poplin
    blake.poplin New Member
    austin
    elkin, NC
    4cylinder 4wd 1996 tacoma
    31" tires
    where did you get your lift kit and what brand is it. Also do the tires rub any
