Tire size, need help
Discussion in '5 Lug' started by Siregar94, Dec 9, 2015.
  1. Dec 9, 2015 at 3:47 PM
    Siregar94
    Siregar94 [OP] New Member
    Joey
    Reg cab 4 cyl 5 lug Tacoma
    None...YET
    What is the biggest tire size I can fit on my stock 5 lug Tacoma? I want something bigger but I haven't bought a lift yet and it's getting time to put new tires on
  2. Dec 9, 2015 at 4:06 PM
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    235/75r15 or 30x9.5r15
    The black box mod also has to be done to prevent rubbing, but these tires should fit without a lift.
    Rolis12 likes this.
  3. Dec 10, 2015 at 11:45 AM
    Siregar94
    Joey
    None...YET
    What exactly is the black box mod?
  4. Dec 10, 2015 at 1:10 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    There is a "black-box" on the rear portion of the front fenders, designed in most part apparently, to keep us from using significantly larger than designed tire sizes on our 5-lug Tacoma. It involves cutting away a section of the rear 'bulge' in the plastic fender liner, and then unbolting a cab-corner cover from the frame to give additional clearance for larger than ~245/75R16.
    https://www.tacomaworld.com/threads/how-to-black-box-removal.357919/
  5. Dec 10, 2015 at 1:17 PM
    HackD
    William
    Also, 5-lug, gearing is an issue as you get higher in tire size. You can fit the wheels on, but you ain't gonna make 'er go if you haven't got your final drive gear ratio right.
    5-lug auto, is a relatively straight-forward (if not inexpensive) regear fix.. 5-lug standard is an odd beast, and isn't quite so straight forward to rectify. 31's are about as far as you want to go, before regearing becomes a factor to consider - unless you live in the Prairies..
    SleazyPetey likes this.
