Tire Size on 4 banger
Discussion in '4 Cylinder' started by raydenking, Jul 8, 2015.
  1. Jul 8, 2015 at 11:47 AM
    raydenking
    raydenking [OP] Active Member
    Ray
    2015 Tacoma Prerunner
    Hey Guys!
    So right now my truck is still completely stock. I have been doing some research and decided to go with the bilstien 5100 3" coil overs. I talked with one of the guys at the shop about putting on some mud terrains. I told him I wanted the Toyo Open Country M/T in 32's but he's pushing for the 33's for whatever reason.
    My question here is whether or not throwing 33's on my 2.7l would just make it totally under powered?
    Any input on this? Thanks!
  2. Jul 8, 2015 at 12:04 PM
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    I have the same truck as you and I wouldn't dream of tossing bigger tires on it, in fact I'm looking at new tires because the Dunlops SUCK and I'm going with the same 245/75/16 for fuel and cost, this truck will never be an off road beast. 33's are 8.4% bigger than what you have now, that is pretty significant. These trucks are pretty slow as is, add that to a 3" lift and you are going to have a very slow truck that gets terrible mileage. If you can put up with an even slower truck than you have now go for it. Or if you are willing to regear to 4.56's you could get close to your original ratio, it will still be heavier and have more wind resistance but will at least move half way okay. I hope I'm wrong but this is my gut feeling, best of luck to you.
    TALLNDIRTY and raydenking[OP] like this.
  3. Jul 8, 2015 at 12:08 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Read the specs on the tires. Most "33" inch tires are usually closer to 32". Either way you're gonna rub and have to trim
    raydenking[OP] likes this.
  4. Jul 8, 2015 at 12:10 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Wat?
  5. Jul 8, 2015 at 12:12 PM
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    FIFY
  6. Jul 8, 2015 at 12:15 PM
    T4RFTMFW
    I have a DCSB Prerunner 2.7 auto with a 220 lb +/- shell with P265/75/16 Cooper ATPs on OEM alloys and 1.75" front/2" rear lift and my tires are about 41 lbs each. The difference in MPG from no lift, no shell and 245 Dunlops is (for me) 4-5 MPG down from my average before list.
    I'm getting 18.5-20 each tank now, was getting 23-24 previously.
    Acceleration with bigger tires is noticeably slower but I don't have a hard time merging. Passing on a 2 lane road is fine but if run short of space, it's slower than I'd like. 2.7 isn't fast to begin with, but it drives just fine with bigger rubber. I do miss the 245 MPG though.
    Stay in P metric tires and watch the weight and you'll be just fine.
  7. Jul 8, 2015 at 12:16 PM
    BassMaster06
    Dan
    South Carolina
    Ok maybe I mispoke, but I always thought that just because it's a 285 doesn't mean it's a true 33" tire, just depends on the brand. Like for example 285 duratracs are 32.8" if I recall
  8. Jul 8, 2015 at 12:16 PM
    raydenking
    Ray
    Very valid point! I agree that the dunlops are terrible. Thanks for your input
  9. Jul 8, 2015 at 12:17 PM
    T4RFTMFW
    285 isn't a true 33" tire, so of course.
  10. Jul 8, 2015 at 12:18 PM
    raydenking
    Ray
    I believe you're correct. I talked to him about 32's but he said the closest he could get to that is a 32.8. Tires involve too much thinking for me!
  11. Jul 8, 2015 at 12:20 PM
    raydenking
    Ray
    Thank you for your input! This is very helpful. How do you like your Cooper ATP's?
  12. Jul 8, 2015 at 12:23 PM
    T4RFTMFW
    I love them. I had Hankook Dynapro ATM RF10s in the same size and they were the absolute worst tires I've ever owned. I had them for 6 months with monthly trips into the tire shop and 2 replacement tires before I had 5k on my initial set and they were equally plagued with issues.
    Avoid them in P metric at all costs.
  13. Jul 8, 2015 at 12:26 PM
    raydenking
    Ray
    Good to know.. Thats the last thing anyone wants after spending that kind of money. I was also quoted on the Hankook MTs. The price sound better than Toyo but I haven't heard a lot of good things about them so far.
  14. Jul 8, 2015 at 12:28 PM
    T4RFTMFW
    FWIW. I got less than 22k out of the Dunlops and they measured at 3/32.
  15. Jul 8, 2015 at 12:46 PM
    T4RFTMFW
    I heard good things of Toyo, but IIRC they are pretty damn heavy.
  16. Jul 8, 2015 at 12:49 PM
    raydenking
    Ray
    LT265/75R16 58lbs per their website
  17. Jul 8, 2015 at 12:55 PM
    T4RFTMFW
    Yeah. That's about double the weight of 245 Dunlops and almost 20 lbs more than my ATPs.
    Likely a turtle with those on but it'll look good.
  18. Jul 11, 2015 at 10:36 PM
    Indy
    Indy Master of all I survey.
    Im on 31s and i really really nedd to regear. The 2.7 is a dog in factory trim, add extra diameter and weight and it is a dying dog.
  19. Jul 11, 2015 at 10:49 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I've got 265/75-16 tires in my 4 banger. Any bigger than that you are probably gonna rub even with a 3" lift from what I've read. They're about 55 pounds a tire and it's not too bad. They measure at 31.7".
    As for drivability it seems fine to me.
    TA 4 and raydenking[OP] like this.
  20. Jul 12, 2015 at 7:21 AM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    I can live with the occasional down-shift (when necessary)...only issue I've experienced from stock gears and taller tires.
    3" lift, no trimming...re-gear is on the list :)
