Tire size on a base model
Discussion in 'Wheels & Tires' started by Grey Jay, Aug 6, 2009.
  1. Aug 6, 2009 at 8:46 AM
    Grey Jay
    Grey Jay [OP] Well-Known Member
    Sudbury ON Canada
    12 TRD
    I am thinking of buying a base crew cab 4x4 Tacoma. If I do I would like to upgrade to the same tires I have on my Frontier. (LT265/75R16) Does anyonme else run these tires?
    I noticed that the tires on the so called off-road package are actually smaller outside diameter than on the base model. Where I am from the difference bewteen base and TRD is almost $6000. Doesn't seem worth it to me. Can the computer be changed to reflect the correct speed /odo readings?
    Thanks for your info,
    Kris
  2. Aug 6, 2009 at 9:11 AM
    Grey Jay
    Sudbury ON Canada
    12 TRD
    Thanks but the TRD crew cab in Ontario does not come with a locker (sucks). I have a rear locker and a front limited slip in my frontier right now. Not happy to part with it. The TRD does come with an extra 1500 lbs towing and a backup camera. Now thats worth 6K!!
  3. Aug 6, 2009 at 11:27 AM
    EricS76
    EricS76 Well-Known Member
    Central Texas
    08 DC SR5 Prerunner Black,08 AC 4x4 SR5 White
    245/75R16 is the stock size for everything without the TRD packages. The TRD package stock tire size is 265/70R16. I changed my stock 245 tires to 265/70R16 and didn't notice any real change in the speedometer. It read slower than it should with the stock tires and still does with the 265/70R16's. 265/75R16s will be a little taller than 265/70R16's.
