Tire Size on my 2.7 4X4 - Advice Needed
Discussion in 'Wheels & Tires' started by Drogers, Apr 5, 2011.
  1. Jul 31, 2011 at 7:39 AM
    #41
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Ok you guys running the p265/70/r16 terra's how much is the size difference going from the 75-70? it fits right on the stock rim right? According to the size post that 70-75 is the sidewall height?
  2. Jul 31, 2011 at 7:44 AM
    #42
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yes the 70/75 is the sidewall height. The 75s will be one inch large in overall diameter.
  3. Jul 31, 2011 at 7:54 AM
    #43
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    So If I am understanding correctly the 265 is larger in width but because its a 70 its less likely to rub the mud flaps or lock on full turn?
  4. Jul 31, 2011 at 11:52 AM
    #44
    TexasTacoma37
    Both 265s are the same width. The 75 is slighty taller. Neither will rub.
  5. Jul 31, 2011 at 12:45 PM
    #45
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    sorry I ment the 265 was wider than the 245. I wish nitto had a p265 in a 75 :( but i guess that much of a difference doesn't matter.
  6. Jul 31, 2011 at 4:18 PM
    #46
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Yes, the 265/70R16 is 20mm wider than the 245/75R16 but only 3.5mm larger in diameter. (265mm x 0.7 vs. 245mm x 0.75)
  7. Aug 19, 2011 at 7:51 AM
    #47
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    for you guys running stock suspension anyone see a difference or have any issues running a p265/75/16 vs p265/70/16? According to the other forums the 75 will have a better change to rub but it seems like such a small difference.
  8. Aug 19, 2011 at 8:08 AM
    #48
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Stock suspension here with 265/75/16 Cooper AT3s. No rubbing at all, although I removed the front mudflaps for aesthetics even before the upgraded tires...it looks a wee bit tight, so I will add 5100s someday and set at .85.
  9. Aug 19, 2011 at 10:12 AM
    #49
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    ok thanks for the info I appreciate it
  10. Aug 19, 2011 at 10:17 AM
    #50
    friction
    Charleston, SC
    '08 4X4 RC SR5
    And to clarify, by "stock suspension" I also refer to the rear. I do not have an AAL, only 3 springs.
