Tire Size on Stock Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD19Pro, Jan 7, 2020.
  1. Jan 7, 2020 at 11:11 AM
    TRD19Pro
    TRD19Pro [OP] New Member
    19 TRDPro
    Hello everyone new Tacoma owner her just picked up my 2019 TRDPro and have stock 265/70/16's. I would like to upgrade to BFG AT KO2's in a 265/75/16. I know my speedo will be off a bit but will I get any rubbing on a stock truck with that new tire size? Thank you everyone!
  2. Jan 7, 2020 at 11:16 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Shouldn't, as the Pro sits 1" higher in the front than my Off Road. I have 265/75/16 Duratracs, and the speedo difference is hardly noticeable.
    TRD19Pro[OP] likes this.
  3. Jan 7, 2020 at 11:17 AM
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    They'll fit just fine
    Superdave1.0 and TRD19Pro[OP] like this.
  4. Jan 7, 2020 at 11:18 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    As already stated, you should be fine with 265/70/16s. That should even fit a stock OR without rubbing.
    TRD19Pro[QUOTED][OP] likes this.
  5. Jan 7, 2020 at 11:23 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    265/75s are fine but I think you should buy some 255/85R16s. ;) Speedometer is off by 7.19% which is a small price to pay if you're half decent at math.
  6. Jan 7, 2020 at 11:25 AM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Agreed! Moar rubber and better clearance. Love my tall skinny Cooper ST Maxxs.
    photogr4x4[QUOTED] likes this.
  7. Jan 7, 2020 at 11:36 AM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Most common misconception, amongst the ignorant is, lifting the truck will enable you to clear larger tires. This has nothing to do with clearing larger tires. You are probably fooled into thinking it will clear with a lift because you fail to realize that the suspension will move UP when compressed (you know suspensions move up/down right?). Once it compresses up, you are right back at where you started and your tires will rub against the exact same spot it rubbed before. Lifting it might let you clear larger tires at RIDE height but the moment you hit a bump or articulate it's rub a dub dub time.
    So...if you don't want to sound like a clown, do not do the following:
    -Tell people you got larger tires to clear with a lift.
    -Tell people how happy you are with performance of your new intake and or exhaust.
  8. Jan 7, 2020 at 11:39 AM
    TRD19Pro
    19 TRDPro
    Thanks for the input and I will go with the 75's. Appreciate the help
  9. Jan 7, 2020 at 11:41 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I have 285/75/16 on my '17 TRD Pro, speedometer seems to be accurate, no rubbing of tires while turning, all good.
  10. Feb 5, 2020 at 7:16 PM
    Shoganai8oh5
    Shoganai8oh5 Well-Known Member
    805
    2020 TRD Pro
    Ok, so I pulled the trigger and ordered the same set as you except I got the AT's. Hopefully I won't rub as well.
  11. Feb 5, 2020 at 8:02 PM
    JoshyP
    JoshyP Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    Serious dude? I have 285/75/17s with a 2.5 inch front lift, TC UCAs set to 3.5 degrees, aggressive CMC and had to trim the shit out of my fenders to get rid of any rubbing. My speedometer is off my 4 MPH, too.
