Tire Size overall diameter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, May 20, 2011.
  1. May 20, 2011 at 10:01 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 44
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum.
    The 265/65r17 is 30.56 inches in diameter.
    The 275/60r17 is 29.99 inches in diameter,
    odometer reads 1.1 miles faster.
    The 265/70r17 is 31.60 inches in diameter'
    odometer reads 2.o miles slower.
    Will installing either of these 2 options affect my towing capacity?
    Will I even notice?
    What is the biggest tire that I can run on a 17x8 rim (without lift kit) & not negatively affect the truck?
    Thanks:eek:
  2. May 20, 2011 at 10:06 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    No it will not effect towing capacity.. You won't even notice a difference if you ran 265/70/R17
