Tire size please don't kill me
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amyonech, Aug 2, 2016.
  1. Aug 2, 2016 at 1:01 PM
    amyonech
    amyonech [OP] Active Member
    Amy
    Long Island, New York
    14 SR5
    Running board, LED interior & plate, weathertech mats. More to come.
    listen, before anyone puts me on the cross... I used the search engine. I'm sorry but I can't find what I'm looking for :(
    Alright so. I have 14 SR5 with a 3" lift, 5100s. I want to run the stock wheels, 16". I'm nervous about the tire height. Do you guys know what the largest tire I can run on a 3" lift with stock wheels? *runs and hides in the corner covering face with blanket*
    Oh also, would like to run KO2s.
    I really really really appreciate everyone's kind words, help and hospitality.
    ChadsPride likes this.
  2. Aug 2, 2016 at 1:04 PM
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
  3. Aug 2, 2016 at 1:08 PM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Run a 255/85/16 and you probley wont rub if you have good caster
  4. Aug 2, 2016 at 1:10 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    265 75 no trimming.:facepalm:
  5. Aug 2, 2016 at 1:46 PM
    Pigpen
    Dan
    Northwest Montana
    I have been running 255/85/16 for a little over a year with no trimming, minor rubbing, and zero problems.
  6. Aug 2, 2016 at 1:54 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I'm running 255/85/16 on stock wheels with spacers on my 07. Without spacers, I rubbed on the control arms enough that it would have eventually caused damage to the tires. With spacers, I rub a little bit on the mud flaps and on the front bumper when turning. A little bit of trimming and bumper rub is mostly gone. Mudflap rub will wear itself clear.
  7. Aug 2, 2016 at 4:23 PM
    Pigpen
    Dan
    Northwest Montana
    Mine lightly rubbed the UCA (not enough to worry me) and also the mud flap (again, lightly). Now I have LR UCAs and nothing rubs anywhere - and my tires measure 33.4" when new. They're probably close to 33" now.
  8. Aug 2, 2016 at 4:30 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Agree with all above
    265/75 no issues
    255/85 minor rub
    285/75 spaces reqd with stick wheel, minor trimming and bmc likely needed- especially with stock uca
  9. Aug 3, 2016 at 7:19 AM
    amyonech
    Amy
    14 SR5
    Thanks a lot guys I really appreciate it. Ended up getting the 265/75. They're on sale at tire rack if anyone is looking to purchase any time soon. :)
  10. Aug 3, 2016 at 8:54 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That is the best option in my opinion. Any bigger and you create other problems to solve.
  11. Aug 3, 2016 at 11:26 AM
    Pigpen
    Dan
    Northwest Montana
    That's part of the fun though, right?
