Tire size question
Discussion in 'Wheels & Tires' started by NiceTaco, Jul 30, 2012.
  1. Jul 30, 2012 at 5:56 PM
    NiceTaco
    NiceTaco [OP] Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Yes I have searched and yes i am dumb...
    I have stock 265 65 17 on my truck.. I plan on putting an 18" rim most likely and I know on stock height max would be 265 65 18..
    I plan on doing a toytec ULK setting it about 2 to 2.5" not I would like a bit wider of a tire I dont care for more height (sidewall) so what size(s) would i be looking at with either a 17 or 18 " rim to get a little more width?
    I am confused at how all this works and I did check out the tire size cal thread.
  2. Jul 30, 2012 at 6:16 PM
    Large
    Large Red
    305/55/18 street tires or BFG makes the km2 in 305/60/18 but you'll need to cut.
  3. Jul 30, 2012 at 6:30 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Could also do a 285/60/18. Fairly common, 32", won't need to trim with the lift.
  4. Jul 31, 2012 at 4:51 AM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    I dont want to be to wide I think 305 would be to wide I still want an AT type tire i just dont care to have huge tires on the truck with the distance to work I travel daily my MPG would kill me.
    I want Just a little wider than stock. So 265 is my width so 270,275 are a wider tire..for example 275 65 17 would be wider than stock?
  5. Jul 31, 2012 at 5:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    The first three numbers (265) indicate width in mm. So yes, 275 > 265
  6. Jul 31, 2012 at 5:30 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Keep in mind that width adds just as much if not more weight than height.
