Tire Size Question
Discussion in 'Wheels & Tires' started by JRod4928, Aug 14, 2012.
  1. Aug 14, 2012 at 6:43 AM
    JRod4928
    JRod4928 [OP] Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    Ok, so the largest tire anyone has reported using on a stock suspension is a 265/75/16 from what I can tell, which is about 31.5", but I want to go a bit farther.
    Does anyone have experience attempting to use 265/75/17 on a stock suspension without rubbing?
    How much front end lift is required to eliminate the rubbing if it occurs? (I'm assuming the rear tire won't rub).
    I'd like to run 32-32.5" tires without a lift and without trimming/rubbing (various reasons) ... bad idea/impossible?
  2. Aug 14, 2012 at 6:51 AM
    fsbrain03
    fsbrain03 Well-Known Member
    Doubtful. You will most likely need to do a bit of trimming with anything larger than the 265. May be close though.
  3. Aug 14, 2012 at 7:04 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    It might work if you drive straight on smooth roads and think light thoughts.
  4. Aug 14, 2012 at 7:05 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    I was afraid of that, lol.
    Wonder if I can buy some Bilstein Adjustables and reuse the stock coils to lift it a small amount (about 1 inch) to accommodate a mid 32" tire. No AAL in the back, a small lift in front would also provide a slightly 'raked' look which I think looks cool.
    Or I could use Spacers..... bleh
  5. Aug 14, 2012 at 7:06 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Hey, I only weigh 160-165, so.... that might work
  6. Aug 14, 2012 at 7:28 AM
    fsbrain03
    5100's would do the trick. I believe they have 3-4 setting. Depending on what they send you.
  7. Aug 14, 2012 at 7:46 AM
    4Wheelin4Banger
    Randy
    .85" on Billies with stock coils could give you the room you need.
  8. Aug 14, 2012 at 7:58 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    That's what I'm hoping for - i guess I will only know if i try, right?
    could also add a 1/4 or 1/2" spacer if bilstein's at 0.85" does not provide quite enough room. dont want to preload the spring too much for ride quality purposes so I wouldnt go further than 0.85". but i dont want to use only spacers because of the laundry list of problems that comes with that.
    In reality, I'd LOVE to go 3" all around, but I'm afraid of the future problems with doing that, and I want to be able to use my Toyota Warranty, I'm only 400 miles into my 100,000 warranty afterall, lol.
  9. Aug 14, 2012 at 12:54 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Who makes a 275/75/16 tire :confused:
  10. Aug 14, 2012 at 12:58 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You can go 3" without having if affect your warranty. Most of us here were still under warranty when we added our lifts. If something goes wrong the dealer has to prove that it was the lift that caused the issue and not the truck itself. I've taken mine to the dealer a couple of times and they never mentioned the lift except how nice the truck looked.;)
  11. Aug 14, 2012 at 1:11 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Nobody:notsure:
  12. Aug 14, 2012 at 1:14 PM
    TexasTacoma37
    Exactly :cool:
  13. Aug 14, 2012 at 1:42 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Meant to say 265/75/17 - gimme a break eh? lol
  14. Aug 14, 2012 at 1:45 PM
    TexasTacoma37
    Okay, who makes a 265/75/17 :confused:
  15. Aug 14, 2012 at 1:50 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    good to hear about the warranty. did you have to take it in for any repairs?
  16. Aug 14, 2012 at 1:58 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Alright alright, I'll take it from the guy who has 1000x more posts than I do.
    So would you mind helping me answer my question now? You understand my plan of attempting to run a tire in the 32-32.5" range - got any valuable input to help a guy out?
  17. Aug 14, 2012 at 2:18 PM
    TexasTacoma37
    Your question was whether anyone had any experience running 275/75/16, then a 265/75/17. I think I answered those questions. Expect a little sarcasm if you don't do your research to make sure those tires actually exist. This is the internet, after all.
    I run a 275/65/18, which is 32.1" tall, and I rubbed even with 1.75" of lift. So I suggest you just stick to the 31.5" range everyone else runs on stock suspension, i.e. 265/75/16 or 265/70/17.
  18. Aug 14, 2012 at 2:20 PM
    TexasTacoma37
    The closest size to what you are looking for that actually exists, in a 17" wheel, is 255/75/17.
  19. Aug 14, 2012 at 5:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    275/70/17 is 32.25 , but you won't clear it on stock suspension
  20. Aug 14, 2012 at 5:47 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    Seems the 275/70/17 is mostly available as an AT tire. Does anybody make a MT in that size?
