Tire size question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WinTheDay, Oct 25, 2012.
  1. Oct 25, 2012 at 5:06 PM
    WinTheDay
    WinTheDay [OP] Active Member
    Oregon
    '12 TRD OFFROAD DBL CAB 4x4
    3"/1" Pro Comp Leveling Lift, TRD Exhaust, Black Tube Steps, 800 watt 5ch digital amp, 6.5" JL Audio components, 10" Rockford Fosgate with custom box
    I just installed the Pro Comp 3"/1" leveling kit on my 2012 Double Cab and am planning on getting getting 17x9's. I know 285/70/17 are a safe size, but what about 285/75s or even 33x12.5? I have no interest in spacers so please dont suggest them! :)
    Im not very knowledgable with Tires so any input would be worth alot to me! Thanks!
  2. Oct 25, 2012 at 5:30 PM
    WinTheDay
    Oregon
  3. Oct 25, 2012 at 8:43 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    All three sizes you suggest are basically the same size, check the tire caculater in search function
    FWIW I run 285/70/17 with very little probs
  4. Oct 25, 2012 at 8:47 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    your wheels also need to have the correct 4.5" backspacing, or else the new tires will rub the UCA and you wont be able to drive the truck. in that case, you would need spacers. there are also like no tire manufacturers that make 285/75/17's, but 285/70's and 33/12.5's should be rather easy to find. you will have to check with the tire makers as well on the 33 12.5's because they may say not to run them on anything skinnier than 10" wheels in which case most tire places wont put them on your 17*9s.. so now you see why most people just stay safe with 285/70/17's?
