??Tire Size Question??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by btdawgs10, Apr 5, 2014.
  1. Apr 5, 2014 at 12:51 PM
    btdawgs10
    btdawgs10 [OP] Well-Known Member
    Alabama
    08 PreRunner SR5 2wd
    I have an access cab prerunner with bilstein 5100s set at 1.75 and the rest is stock i was wondering if i could fit 275/70/r16 with no scrubbing or if 265/70/r16 is the biggest i could fit even with the front lifted
    ANY HELP IS APPRECIATED
  2. Apr 5, 2014 at 1:29 PM
    zomg
    zomg Well-Known Member
    NOLA
    08 PreRunner SR5
    TRD CAI, Ultra-Gauge, All Weather Floor Mats, Rear Spring TSB, Avid Offroad Sliders, Spidertrax, Dynomax Superturbo, Bolt-on Grille
    I ran 265\75r16 Goodyear Duratracs without rubbing. I just switched to Coopers in 255\85r16 & have minimal rubbing only in reverse when backing out of the driveway. I am running 5100s at 1.75 with stock wheels & Spidertrax spacers.
  3. Apr 5, 2014 at 6:47 PM
    btdawgs10
    Alabama
    did u mean u switched to 275 and would i have to get spacers
  4. Apr 5, 2014 at 8:04 PM
    zomg
    NOLA
    08 PreRunner SR5
    No, the biggest tire that can be run on a stock suspension without rubbing is 265/75r16. I had minor rubbing on the mud flaps, so I took them off. Later, I added 5100s set at 1.75 & the spaces for the look. Last week I changed to 255\85r16, which are taller & skinnier. The new tires do rub, but I suspect that will lessen or stop if I remove the spacers or start cutting.
    The 275/70r16s are slightly shorter & wider than the 265\75r16s, so you should expect some rubbing without spacers. You may need the spacers just to clear the spindles or uca ball joints with those tires.
    Also, lifting the front using 5100s spacers, etc does not change the suspension components enough to clear larger tires. If you want to fit significantly larger tires you will need to change UCAS, spindles, do a cab mount chop, etc.
    A better place for this question would be the wheels/tires section. There is a lot more specific info for tires & many of the other members are more knowledgeable on this subject.
  5. Apr 5, 2014 at 10:25 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    I ran my 265/75/16 with no rubbing before lift. Others have different stories. Depends on rim/backspacing/etc.
  6. Apr 5, 2014 at 10:49 PM
    stephenw13
    stephenw13 Active Member
    Phoenix
    2012 4x4 DCLB Sport Upgrade
    My 2012 DCLB 4x4 is stock and has 265/60/18 with no rubbing. However I have not been off road with her.
  7. Apr 6, 2014 at 3:53 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    275/70/17 is basically the same size as 275/65/18's (32x10.8") that I ran in the past with a 2.5" lift without spacers and factory 18's.(18x9, 5.4" backspacing). Only minor plastic rubbing in reverse at full lock. I doubt you will have issues, maybe crank it up to 2.5" if needed.
  8. Apr 6, 2014 at 9:38 AM
    btdawgs10
    Alabama
    If I get spydertrex 1.25 wheel spacers all the way around can I fit 275/70/16 with no rubbing issues
  9. Apr 6, 2014 at 9:43 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    with the 1.25 spacers, you will get some rubbing at full lock and when cycling the suspension, it you go to the .75" spacers, that problem will go away.....tolerances are close, I rubbed @1.25", but the .75" Bora's were perfect....running 265/70/17...stock suspension, no lift, Blisteins HD's all the way around....
