Tire Size Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by justinh384, Feb 22, 2018.
  1. Feb 22, 2018 at 3:28 PM
    justinh384
    justinh384 [OP] Active Member
    Justin
    Wrightsville, GA
    2017 White Toyota Tacoma SR
    I recently purchased a 2017 Tacoma SR crew cab. I was wondering on the fitment of some tire sizes. I've searched the forum but can't find a definite answer.
    If I kept the stock steelies, would 265/75r16 fit without rubbing?
    If I found some Tacoma 16" allow wheels, would 265/75r16 fit without rubbing?
    If I found some Tacoma 17" wheels, would 265/70r17 fit without rubbing?
    If I found some newer 17" 4runner wheels, would 265/70r17 fit without rubbing?
    If I found some older 16" 4runner wheels, would 265/75r16 fit without rubbing?
    Thanks For The Help
  2. Feb 22, 2018 at 3:32 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    as long as you do not change any suspension you should be fine with any of those above.
    worst case maybe rub mud flap. and that only depends on your tire choice.
    Many run that size on plenty of options of wheels and no issues.
    I think I'm one of the few who actually had an issue.
    2017 TRD off road and with konig six shooter wheels with a 0mm offset, 17" wheel with a 265 70 17 goodyear duratrac. I rubbed on the mud flap only slightly, probably could've been fixed with a heat gun alone but I just took them off.
    You won't have any sort of body mount rubbing or control arm rubbing at that size and wheel option.
  3. Feb 22, 2018 at 3:33 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Did you use the search button here? That’s too many questions to ask all at once...lol
  4. Feb 22, 2018 at 3:42 PM
    Bagow
    Bagow Well-Known Member
    Arizona
    2016 DCSB OR 4x4
    Yes
  5. Feb 22, 2018 at 3:44 PM
    Joe23
    he said he did search lol.
