Tire size question
Discussion in 'Wheels & Tires' started by poomero, Jan 21, 2019.
  1. Jan 21, 2019 at 9:31 AM
    poomero
    poomero [OP] Member
    Josh
    2017 Tacoma TRD
    I am sorry if this has been talked about but I cant seem to find and info on it.
    I have a 2017 TRD Off Road and I am looking and putting new tires on it. Right now the truck is stock and I want to leave it that way. It has 265/70R16 on it and I would like to put a 305/70R16 on it. My question is will it rub if I go this big? Will I have to put a wheel spacer on it and if so what size?
    Any info is greatly appreciated.
  2. Jan 21, 2019 at 9:34 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
  3. Jan 21, 2019 at 9:37 AM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Not even close
  4. Jan 21, 2019 at 9:39 AM
    poomero
    poomero [OP] Member
    Josh
    2017 Tacoma TRD
    Thanks Mitch, I thought someone would have asked this already but I didnt find it.
    Mitch76 likes this.
  5. Jan 21, 2019 at 9:44 AM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    That will not work at all, it will tear your fender off and destroy your suspension lol
  6. Jan 21, 2019 at 9:53 AM
    poomero
    poomero [OP] Member
    Josh
    2017 Tacoma TRD
    Would those fit if I did a 3 inch lift?
  7. Jan 21, 2019 at 9:55 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Just curious, but what’s the point in even putting that big of a tire on? You doing some serious trail riding?
    ripcalifornia likes this.
  8. Jan 21, 2019 at 9:55 AM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    you'll still need to do a ton of trimming to the fenders/wheel wells and factor in the offset of whatever wheels you get
    You'll need new UCAs and probably want a regear too
    For a daily driver that would be a nightmare
    Rustytaco71 likes this.
  9. Jan 21, 2019 at 10:22 AM
    poomero
    poomero [OP] Member
    Josh
    2017 Tacoma TRD
    Yes I do heavy trail driving. Not a lot of wheeling but I do go out in the forest a lot. I ride dirtbikes and some of the places I go it would be nice to have a little more ground clearance.
  10. Jan 21, 2019 at 10:38 AM
    Rustytaco71
    2018 4Runner
    You’ll want a taller tire then if you want more ground clearance, not wider. I would recommend seeing some of the “skinny” tire options available or go down to 285/75’s for your needs if that’s what you’re after. The 305’s you mentioned are shy of being 33’s.
  11. Jan 21, 2019 at 10:40 AM
    poomero
    poomero [OP] Member
    Josh
    2017 Tacoma TRD
    Also, isnt a 305/70/r16 only 2 inches bigger than a
    I know I thought about the skinny option also but I tow a travel trailer and a wider profile would be nice. I will have to figure it all out and see what I come up with.
  12. Jan 21, 2019 at 11:21 AM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    Your problem is stock suspension, you'll need to upgrade if you want to fit either of those sizes
