Tire size to fill wheel well
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggiusti, Mar 16, 2016.
  1. Mar 16, 2016 at 5:17 AM
    ggiusti
    ggiusti [OP] New Member
    Gary
    2013 Tacoma trd sport double cab
    Tonneau,Tint
    2013 Taco Trd sport double cab need some recommendations for tires to fill wheel wells but not necessarily lift truck, looking for tire size on 17" rims on/off road tires any help or pics would be great!!
  2. Mar 16, 2016 at 5:23 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    DustStorm4x4 likes this.
  3. Mar 16, 2016 at 5:36 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    without a lift that is as big as you can go without issues
  4. Mar 16, 2016 at 6:37 AM
    Pigpen
    Dan
    Northwest Montana
    Yep. As stated above.
    /thread
  5. Apr 13, 2016 at 5:44 PM
    ggiusti
    Gary
    Tonneau,Tint
    Thanks for the tips. So if I want to go bigger tires I need a lift then? I'm trying to keep it same height to get in the garage! I like the larger tires though thinking of BF ko2's. Any opinions?
  6. Apr 13, 2016 at 7:21 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    BFG KO 2's are well respected tires. Are you planning to off-road? Or simply want them for appearance?
    If not and you want fuel mileage, quiet ride, etc.. look at something like Michelin LTX M/S 2's or LTX Defenders (same tire).
  7. Apr 14, 2016 at 5:02 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    My next set are ST Maxx's like Kyitty has. Sharp looking truck man. And congrats on the banner spot!
    Kyitty likes this.
  8. Apr 14, 2016 at 7:12 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Also check out the general grabber AT2. Very aggressive for an AT and very cheap. I got mine for $600 shipped to my door for 4 in 265/70r17 off discounttiredirect.com
  9. Apr 16, 2016 at 10:42 AM
    Poky
    Poky Member
    Gio
    Va
    2013 tacoma base
    Stock
    how do you guys feel about 255 75 15 on a base regular cab Tacoma 2.7 manual 5 speed? Stock rims
