tire size w/ just coilovers & all pro bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by captaininsaneo, Nov 30, 2011.
  1. Nov 30, 2011 at 1:22 PM
    captaininsaneo
    captaininsaneo [OP] Member
    Erik
    Murrieta, CA
    07 Tacoma v6
    DR coilovers, total chaos UCR's, 44 flowmaster, 17"beadlock wheels, 32" tires
    Hey guys...I have an 07 tacoma prerunner with some Donahue racing coilovers and total chaos UCR's. I'm looking to get an all pro front and rear bumper and wanted to know recommendations on tire size for this set up. I'm also getting some squeaking coming from my front suspension when I go over bumps in the road...do i just need to grease up my a arms. I don't get this sound when it rains.
  2. Nov 30, 2011 at 1:25 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    What is the total amount of lift you're getting out of the coilovers? Do you have any rear suspension modifications? TSB leafs, AAL, etc...?
    Fink
  3. Nov 30, 2011 at 1:28 PM
    captaininsaneo
    Erik
    Murrieta, CA
    07 Tacoma v6
    3 in the front no rear mods
  4. Nov 30, 2011 at 1:36 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i had a 3" lift with the All Pro front bumper for almost 2 months. i was running 265/75/16's at the time and had plenty of clearance and no rubbing. and i bet i couldve had 33's with out any rubbing.
    lets say theoretically you have 33' tires and it rubs..it's going to rub on the body mounts while turning at full lock. there's a mod for that, easy to do but requires cutting a portion of the body mount and welding some metal to re-box the body mount. somewhere here there is a good "how to" on the body mount mod.
  5. Nov 30, 2011 at 1:45 PM
    Fink
    Orlando, FL
    Now I'm confused. You have a 3" lift up front with a completely stock rear? :confused:
    Fink
  6. Nov 30, 2011 at 1:47 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Bro lean... but yea 33's should fit perfectly up there.
  7. Nov 30, 2011 at 1:48 PM
    Fink
    Orlando, FL
    No kidding.
    If it were me...I'd fix the lean before putting money into tires. If you are just dying for some tires, then I agree that 33's would fit just fine.
    Fink
  8. Nov 30, 2011 at 4:59 PM
    captaininsaneo
    Erik
    Murrieta, CA
    07 Tacoma v6
    Thanks guys. Think I'll run 33's as I'm lookin to get some 4" camburg spindles and fenders for the front, deaver springs for the rear along with some bilstein shocks. Do you guys recommend changing my gear ratio to 4.56? Is it really a big difference in torque and mpg.
  9. Nov 30, 2011 at 5:24 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Dont need to regear till you slap on 35's
