tire size with a 2" leveling kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pcasey58, Jun 29, 2009.
  1. Jun 29, 2009 at 7:27 PM
    pcasey58
    pcasey58 [OP] Member
    central NJ
    96 tacoma
    3 in body lift
    hey everybody, im getting a 2 inch leveling kit installed tomorrow and id like to get new wheels and tires before summers over. i have 32" BFG all-Terrains on her now but id like to go a little bigger. what do you think would be a good size tire with the leveling kit installed? thanks
  2. Jun 30, 2009 at 4:02 AM
    ChrisYoTaCoMa
    ChrisYoTaCoMa Chrome's for Harleys and old farts
    Estero, Floriduh
    00 Taco 4x4 Ex cab 2.7 sr5 AT
    New Pioneer stereo, and all 4 speakers with Infinity components. Sirius satellite radio. Deckplate mod done. Door buzzer silenced forever thank God, tinted windows, vent visors, hood protector(bug guard), ceramic pads and new rotors, dechromed EVERYTHING. 2" Lift front 3" rear. Skyjacker AAL's and replacement leafs(and front spacers) from Fatbobsgarage.com. Skyjacker 7000 Hydro rear shocks, those Bilstein 5100 fronts are coming soon!
    The 4x4 shop by me told me with my 2" lift 32 was as big as I want to go. You may get to 33, but a little rub.
  3. Jul 1, 2009 at 7:23 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    32's fit with stock suspension?
  4. Jul 1, 2009 at 7:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a 265/75/16 is basically a 32 inch tire, so yes........a 32 inch tire will fit stock suspension on the 6 lug tacos.
  5. Jul 1, 2009 at 7:25 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Yes. 32"s are the biggest you can go on stock suspension...there will be a little bit of rubbing though.
  6. Jul 1, 2009 at 7:56 PM
    blkcoma32
    Illinois
    Cool, and 33's with 2.5 inches of lift w/ the right spacing right?
  7. Jul 1, 2009 at 7:56 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    i was running 33x12.5 on a 2inch lift, rubbed alot, you can always do the pinch weld mod
  8. Jul 1, 2009 at 8:06 PM
    blkcoma32
    Illinois
    how was the power loss with 33's? i want to run 33's but don't want to regear it and make my mpg's even worse(can't hardley afford to drive it now!)
  9. Jul 1, 2009 at 9:19 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    you will feel a little loss of power, and loose 1-2mpg's
    But Its not enough to where you NEED to regear.
  10. Jul 2, 2009 at 12:29 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    i notice the power loss, it was not that bad, I usually try to drive it easy. Also be prepare to get a running start when approaching hills. I loss about 3-4 mpg. I will be re-gearing soon, either 4.56 or 4.88 not sure yet.
  11. Jul 14, 2009 at 5:36 PM
    blkcoma32
    Illinois
    So what all do i need to fit 33's?
  12. Jul 14, 2009 at 6:00 PM
    jj95
    jj95 Member
    Panama City
    95 tacoma 4x4
    you can clear 33's with 2.5 leveling kit
  13. Jul 15, 2009 at 7:00 PM
    blkcoma32
    Illinois
    How much wheel well triming though?
  14. Jul 16, 2009 at 12:49 AM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    All I know is that my truck has all stock suspension and it's running 31x10.50R15's. I plan on the 1.5" spacers up front and a 3" or 4" block in the rear with 33x12.50R15's
  15. Jul 16, 2009 at 6:57 AM
    FightFire48
    FightFire48 Taco Monster
    Will
    Spokane, WA
    04 Taco dbl cab
    3" Toytec lift AEM BruteForce CAI Gibson exhaust 2 - Rockford Fosgate 8's
    I was thinking of putting 32's or 33's on my 04 tacoma pre runner dbl cab. I have a 2 inch leveling kit will that fit and i understand that it might rub a lil bit.
  16. Jul 16, 2009 at 10:16 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    so, the rear is already 2 inches higher from the factory, your going to go up 4 inches in the back and only 1.5 up front... bad idea.
    the rear will sit like 4.5 inches higher than the front...
