Tire size with stock suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01 tacoma, Jun 17, 2011.
  1. Jun 17, 2011 at 5:20 PM
    01 tacoma
    01 tacoma [OP] Member
    Pennsylvania
    01 SR5
    Hey guys. I'm considering getting a different set of wheels and tires. What would be the biggest tires you could fit with a stock suspension?
  2. Jun 17, 2011 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Should be able to fit 265/75s on a 16x8 wheel with 0 offset. That is about a 32x10.4 in non metric terms. Probably see a lot of rubbing without a lift if you go bigger.
  3. Jun 17, 2011 at 9:32 PM
    geoff06
    geoff06 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    I agree ^. I've been running 265/75/16s since I bought my truck. Even with a 3" lift, there was minimal rubbing from the front wheels being at full lock (might have just been because of uneven terrain), but I'm running 1.5" spacers right now and haven't noticed any rubbing since installing them
  4. Jun 17, 2011 at 10:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Search enabled. Thanks for the heads up. :cool:
