tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by santa4x4taco, Aug 30, 2016.
  1. Aug 30, 2016 at 6:18 PM
    santa4x4taco
    santa4x4taco [OP] Well-Known Member
    front: 5100s set at .85 with the 1.6" eibach springs, also have a 1/2 inch spacer on both sides and 1/4 spacer on driver side for taco lean.(this brings me to about 2.95 inches) Total Chaos UCAs
    rear: AAL from toytec (don't remember if it was 2 or 1.5 inches)
    anyway...what size tire can I run. I don't mind trimming.
    looking at getting 20x12 -44 offset with BS at 4.75 with a 33x12.50r20 tire..will I be good with this set up?
  2. Aug 30, 2016 at 7:00 PM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    Most people on TW don't run 20s i can only count like 4 people haha. but people have done it, its all over instagram. you have to remove the mud flaps
  3. Aug 30, 2016 at 7:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can run that size, but it is likely necessary you'll have to do a CMC (cab mount chop) hammer the pinch weld and some plastic trimming if you don't want to rub at all, even with your tire stuffed in the wheel well i.e. hitting a bump while turning.
  4. Aug 31, 2016 at 5:48 PM
    santa4x4taco
    anyone running 18x12 -44 offset?
  5. Jan 26, 2017 at 12:58 PM
    whitetaco97
    whitetaco97 Well-Known Member
    Tyger
    2017 White TRD sport
    Bring out the sawzall/dremel when running a x12
