Tire size
Discussion in 'Wheels & Tires' started by slateboi17, Oct 6, 2017.
  1. Oct 6, 2017 at 12:00 PM
    slateboi17
    slateboi17 [OP] Member
    Gabe
    Sacramento CA
    04 White SR5 TRD Double cab
    LED lights, BFG KO2’s, sliders
    So I have a question on tire size and I was hoping I could get some help. I have a two inch spring spacer on the front springs and so I want to get the biggest tire size. I have the stock wheels but want to get the biggest size all terrains or Duratracs that I can get but I’m new to the tire world. Any help would be great.
  2. Oct 6, 2017 at 12:32 PM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    You will need to install wheel spacers, if you plan to run larger size tires on your stock wheel. It can potentially rub your upper control arm depending on the tire size you choose.
    Most guys will go with a 32"-33" tall tires with a 2" lift. Remember, the bigger the tire size the more you have to trim to make everything work. A cab mount chop is also recommended for anything larger than stock size to avoid rubbing at full flex.
    Vuth
  3. Oct 6, 2017 at 3:38 PM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    Have you tried searching? Tons of first post threads just like yours asking what is the biggest tire you can fit...
    If you search you can get a better idea as there are tons of factors in determining that, all tires run different true sizes, have different shapes, lifts are different, ect. Seriously, use the search button and read some threads, you will get more info and a better idea (or maybe change your idea as biggest isn't always best for a situation).
    Tyler
