Tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08DFull, Feb 3, 2018.
  1. Feb 3, 2018 at 7:35 PM
    08DFull
    08DFull [OP] Member
    Damian
    2008 Toyota Tacoma
    So I have a 2008 Tacoma, and I just bought 17x10 Moto metals, and I’m already planning on doing a 3” lift and I just want to make sure 33s will fit fine, if not I’ll go smaller if anyone has any info that’d be great, thanks
  2. Feb 3, 2018 at 7:38 PM
    2007tacoman
    2007tacoman Member
    2007 White Tacoma TRD Off Road
    What is the offset of the wheels you bought?
  3. Feb 3, 2018 at 8:03 PM
    08DFull
    08DFull [OP] Member
    Damian
    2008 Toyota Tacoma
    -24mm
  4. Feb 3, 2018 at 9:24 PM
    Pigpen
    Dan
    Northwest Montana
    :sawzall:
    stickyTaco and BWilley like this.
  5. Feb 3, 2018 at 9:34 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    -24mm is approximately a 2.25” wider stance (sticking out further) than factory, depending on your original wheel. Oem wheels are around +30mm. That’s quite a bit. For example, my wheels are 0mm offset, which is about a 1” wider stance and they perfectly match the factory fender flares. The further out your wheels sit, the more pressure it puts on the wheel bearings. Also, your tires will really stick out past the fender flares unless you put new flares on. Just food for thought.
    MolonLabeTaco likes this.
  6. Feb 4, 2018 at 7:18 AM
    08DFull
    08DFull [OP] Member
    Damian
    2008 Toyota Tacoma
    I was kinda planning on them sticking out quite a bit, I’m more going for the stance look, but I’m just wondering in tire size with a 3” lift if I will have to trim anything, or will they be okay, and I’m totally fine with going to a smaller tire so I don’t have to trim
  7. Feb 4, 2018 at 10:00 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    You will have to trim
  8. Feb 4, 2018 at 1:29 PM
    08DFull
    08DFull [OP] Member
    Damian
    2008 Toyota Tacoma
    What if I go with a smaller tire?
  9. Feb 4, 2018 at 1:33 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    265 - no trimming
    285 - Trimming and CMC
  10. Feb 4, 2018 at 2:28 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    255 is not going to be a good choice for a 17x10.
  11. Feb 4, 2018 at 2:31 PM
    geekhouse23
    Fixed.
    stickyTaco[QUOTED] likes this.
  12. Feb 4, 2018 at 6:18 PM
    2007tacoman
    2007tacoman Member
    Why is 275 not a more popular option?
  13. Feb 4, 2018 at 7:41 PM
    08DFull
    08DFull [OP] Member
    Damian
    2008 Toyota Tacoma
    So 275 or 31” would be fine??
  14. Feb 4, 2018 at 7:46 PM
    BenSando
    BenSando Well-Known Member
    2017 Silver DCSB OR
    Go with 33x12.5....You’ll have to trim. 285’s aren’t going to provide the “stance” look.
  15. Feb 4, 2018 at 7:51 PM
    08DFull
    08DFull [OP] Member
    Damian
    2008 Toyota Tacoma
    I honestly don’t know much about the 285’s, 275’s so what you guys are saying 33’s are going to be too much, and 32/10.5r17 are going to be too tall??
  16. Feb 4, 2018 at 7:57 PM
    Pigpen
    Dan
    Northwest Montana
    Tall isn't the issue. It's width. Wide and offset rub.
  17. Feb 4, 2018 at 9:57 PM
    08DFull
    08DFull [OP] Member
    Damian
    2008 Toyota Tacoma
    So basically no matter what with the wheel size I bought I’m going to have rub?
    Patcakess24 likes this.
