Tire size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Holland83, Feb 12, 2018.
  1. Feb 12, 2018 at 3:08 PM
    Holland83
    Holland83 [OP] Member
    Mississippi Delta
    2016 tacoma quicksand
    I’m curious from people who have upgraded their tires to all terrain tires what size you go up to? I wanna put b f Goodrich all terrain ko2 on it . I would like to go up a size or 2 without them rubbing . Any info is appreciated .
  2. Feb 12, 2018 at 3:20 PM
    Fallsguy
    Fallsguy Well-Known Member
    Would help to know what your truck is. Sport , off road ??rim size ??
  3. Feb 12, 2018 at 3:34 PM
    ls7alex
    ls7alex Well-Known Member
    Newark
    Taco gang
    265/75/16
    265/70/17
    there's a tire calculator on this forum you can use, but the equivalent of the size above is pretty much consensus the biggest you can go. Some ppl squeeze in a 33 without problems by going skinnier to a 255
  4. Feb 12, 2018 at 3:43 PM
    Holland83
    Mississippi Delta
    It’s a t r d off road
    There are 265/70R16 on it now
  5. Feb 12, 2018 at 3:44 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Pizza cutters 255/80 16 or if your real brave 255/85 16
    No rubbing!
  6. Feb 12, 2018 at 4:38 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    275/70/17 on KO2’s.
  7. Feb 12, 2018 at 4:57 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    as others have already mentioned 265/75/16 is it.. if you go to wide the tires will rub on UCA so you'll need new wheels with lower offset which then pushes the outside of the tire further out and as a result will cause rubbing on mud flap area when turning.. running bigger tires is possible just requires work.. as far as just a simple tire swap nothing else .. stick with 265/75/16's
