Tire size!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PHYSICSdaddy, Jul 31, 2018.
  1. Jul 31, 2018 at 12:55 PM
    PHYSICSdaddy
    PHYSICSdaddy [OP] Member
    Manuel
    Tacoma
    Do 285/70/17 rub on A 2017 taco?
  2. Jul 31, 2018 at 12:57 PM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    should skip straight to 40/15.5/26, will only need cab mount chop
  3. Jul 31, 2018 at 12:57 PM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Depends on how many drinks you buy them first.
    dagsamp, Masterofnone, BlakeM and 4 others like this.
  4. Jul 31, 2018 at 12:58 PM
    doorsidedown
    doorsidedown Well-Known Member
    Some do, some dont. Worst case scenario...
    :sawzall:
  5. Jul 31, 2018 at 1:01 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Assuming you only drive straight, I don't think it's a problem. If you plan on using the steering wheel, you might run into issues.
    Some complain of problems, some don't. I'd figure rubbing.
    BlakeM and PHYSICSdaddy[OP] like this.
  6. Jul 31, 2018 at 1:19 PM
    PHYSICSdaddy
    Manuel
    Tacoma
    So the 275 is a safer option I assume.
  7. Jul 31, 2018 at 1:25 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    read my signature...at least follow the links and read those.
    Prairie Hawk likes this.
  8. Jul 31, 2018 at 1:38 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
  9. Jul 31, 2018 at 1:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you are a physics guy then you understand spatial relationships. If you understand spatial relationships then take a look at your stock tire when it's cut all the way left or right. You will then understand what will happen when your tire grows a inch or so. There you go!
  10. Jul 31, 2018 at 1:44 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Lol I was thinking the same thing ...
  11. Jul 31, 2018 at 1:59 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Buy them, throw them on and see what have and let the rest of us know if they do! Lol.
  12. Jul 31, 2018 at 2:49 PM
    Doc's Rig
    Doc's Rig Your opinion is not statistically significant
    Doc
    The Natural State
    2016 4x4
    Mine rubbed even with a three inch lift. I also had to do a CMC. It's not just tire size, but rim offset/backspace. And all 285/70/17 aren't the same size. Use the search and you'll find out all you want.
  13. Jul 31, 2018 at 2:58 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    265/70/17 or 265/75/16 are the largest tire with no rubbing.
    PHYSICSdaddy[OP] likes this.
  14. Jul 31, 2018 at 3:27 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    negative still too wide.
    265 70 17, 255 85 16 (when nothing is changed and stock wheels are used), 265 75 16 are the biggest you can fit guaranteed without rubbing issues.
    Some will say you can run 285 or 275 with no cutting or rub, its all a matter of what lift, wheel, alignment you have.
    for me having 3.6 caster, 2.5" lift and 4.5" back spacing 0 offset I had to beat the pinch weld flat and cut the body mount to fit a 285 70 17.
    And that was to fit it through full lock side to side and full articulation.
  15. Jul 31, 2018 at 6:22 PM
    PHYSICSdaddy
    Manuel
    Tacoma
    Thank you. I’m definitely lifting it
  16. Jul 31, 2018 at 7:39 PM
    Joe23
    You'll still likely need to cut...
