Tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justiced2245, Dec 1, 2019.
  1. Dec 1, 2019 at 12:58 PM
    Justiced2245
    Justiced2245 [OP] Member
    Justice
    2008 tacoma dc TRD
    Leveling kit
    Will 33’s rub with a leveling kit on my tacoma? Could really use some help on this.
    Hobbs likes this.
  2. Dec 1, 2019 at 1:03 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :thumbsup:
    KlunkerBiker likes this.
  3. Dec 1, 2019 at 1:07 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Yes. Welcome to the forum :cheers:
  4. Dec 1, 2019 at 2:57 PM
    DG92071
    DG92071 Well-Known Member
    Which specific leveling kit? Or how much does it lift and where does it lift?
  5. Dec 1, 2019 at 3:01 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    255/85-16 (or 255/80-17) on OEM wheels are your best bet for 33” fitment without contact to the body of the vehicle.
    1-2” of lift can suffice depending on your choices and how aggressive you drive.
    Short answer though, Yes. Yes they will rub. And yes you should just get 32s ha.
  6. Dec 1, 2019 at 3:05 PM
    BullMoose
    BullMoose BullMoose
    Mississippi
    2017 DCSB TRD-OR 4WD
    Depends on tire width and wheel offset. For most the answer is yes, and a cab mount chop and some fender liner trimming is required. Tall and skinny tires (like a 255/85r16) would probably be less likely to rub than a wider 33 (like a 285/75r16.
  7. Dec 1, 2019 at 3:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    Depends a little on the lift.
    Depends a lot on fitment of the wheel in use.
    Depends a fair amount on how you get to 33". Several combinations of tread width to aspect ratio for a certain wheel diameter will = 33"
    But odds are you'll rub unless you've planned really well.
