tire size
Discussion in '1st Gen. Tacomas (1995-2004)' started by tocofrank01, Mar 1, 2020.
  1. Mar 1, 2020 at 9:33 PM
    tocofrank01
    tocofrank01 [OP] New Member
    2001 tocoma dc prerunner
    air bag helper springs 1.5 inch block lift rear Bilstein 5100 front Bilstein 5100 oem coils 2.5 lift, 12inch sundown sa12 sub
    hi, i got the 01 prerunner 3.4 i got 2.5 inch lift up front and 2 inch in rear, i have 265/70/16 stock size and i want to get 285/70/17, but i have 4.10 gear ratio will i be ok? Thanks
  2. Mar 2, 2020 at 8:43 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    OK in what sense?
    Your gear ratio will work, and then you can decide if you want to change it at all after you put the new tires on - that will really depend on how you use the truck, whether it's a MT or AT, etc.
    You're likely to need to do a bit of pinch weld work (and possibly firewall persuading) in order to fit the tires; how much will depend on the specific tires and wheels you decide to go with. There's actually quite a bit that goes into that determination, and you can read about all those things here:
    What size tires fit my (lifted) Tacoma?
  3. Mar 2, 2020 at 9:14 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Have you tried searching?
    There's even an entire sub-section dedicated to tires and wheels.
    Doesn't really matter that you have 4.10's. if you put bigger tires on, it will be over geared no matter what you started with. Plenty of people run the stock gears on 33's, mostly they are mall crawlers, though. If you plan to off-road with it, I'd re-gear.
    There are lots of on-line calculators that help you figure out what yo need based on your current gears, tire size, transmission type, etc...
  4. Mar 2, 2020 at 10:37 AM
    tocofrank01
    ok thank you really appreciate it.
  5. Mar 2, 2020 at 11:19 AM
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
    You’ll be fine. I’m running 285s on the stock 4.10 gears and it still runs good
  6. Mar 2, 2020 at 11:28 AM
    tocofrank01
    Sweet deal thanks bro, sick truck btw
  7. Mar 2, 2020 at 1:45 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    You can do it with 4.10's itll just suck on any kind of incline especially if you have a heavy truck.i speak from current experience...ie what I'm running for now.
    Also the tire fitting matters on what upper control arms that you have and how much backspacing the rims have. I have total chaos arms and rims with a pretty significant offset and I had to beat the crap out of my fire wall.
    Stock ams and less backspacing probably not as much but you'll rub the frame.
