Tire Size??
Discussion in 'Wheels & Tires' started by andrewarch23, Jul 7, 2020.
  1. Jul 7, 2020 at 12:06 AM
    andrewarch23
    andrewarch23 [OP] New Member
    2016 Black Tacoma Sr5
    Hey, I am an owner of a 2016 Sr5 Tacoma and I'm looking on getting new tires. I have no lifts or any modifications on the suspension or etc. What is the biggest size tire I can get without having to worry for rubbing or any trimming.
    Thanks,
  2. Jul 7, 2020 at 1:22 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  3. Jul 7, 2020 at 1:51 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    What @Plain Jane Taco noted. Just bear in mind that tires are a lot like shoes in that some brands run larger than others, even in the same size. So depending on what tire you get into, you may (stress may) have some minor rubbing on the front mud flaps/splash guards at near full lock of the steering wheel.
  4. Dec 30, 2021 at 1:27 PM
    Discount Tire
    Arizona, USA
    A 265/75R16 will fit most newer stock Tacoma's with little to no rub. One of the best ways to confirm prior to an order is use a size calculator like we offer here
    Discount Tire size calculator | Discount Tire
    Then figure out how much bigger the new tire is going to be compared to stock. In your case the stock tire was a 245/75R16 so the 265/75 would be 3/4" wider so 3/8" on each sidewall and 1/2" taller in the sidewall. It should work without any issues.
    We are happy to help further. PM on the way
    Tarheel275 likes this.
